SC220 RICOH MP5001
  • Anjaskaseto
    • Nov 2014
    • 55
    [Error Code] SC220 RICOH MP5001
    good day all ...
    I have a ricoh mp5001 machine, lately appear error SC220.
    this case makes me annoyed. in fact all I've replace the Laser Unit, IPU, IOB, BICU, Power Supply, PCDU, Control Board.
    But the problem is not finished
    If anyone could help in this case?
    Thank you
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: SC220 RICOH MP5001
    Next step I'd try would be door switches, if one of them is a bit fritzy it will affect the laser.
    Hit it.
      Originally posted by Anjaskaseto
      good day all ...
      Thank you
      you replaced all those parts ( shotgun approach )
      did you happen to "reset the error code" in service mode?
      you made sure ALL connectors are seated properly?
      are you sure you used good parts and not ones taken from the " Scrap Yard " ?
      • Anjaskaseto
        • Nov 2014
        • 55
        yes of course I took part from a good machine.
        • Anjaskaseto
          • Nov 2014
          • 55
          thank you ...
          I tried the door switch, but it didn't work
          • anothertech
            • 1768
            I've seen that caused by a loose ground wire in the transfer roller case.
