Fuser fuse for MP C2004ex - error code 544-02
  • AjitN
    • Mar 2009
    • 287
    [Error Code] Fuser fuse for MP C2004ex - error code 544-02
    Greetings To All
    Fuser sleeve got damaged due to paper jammed and machine started giving error code SC 544-02.
    We replaced compatible Sleeve but we need to add Reset Fuse in fuser module.
    Can anybody please tell me exact rating of reset fused which can be use in MP C2004ex.
    Regards
    • 36833
    Re: Fuser fuse for MP C2004ex - error code 544-02
    Originally posted by AjitN
    Greetings To All
    Regards
    Ricoh used to tape a fuse to the bottom of the box that a new fusing unit came.
    • JDYAL
      • Sep 2008
      • 186
      Slimslob is right you should of had the fuse in the box the sleeve came in. Hope you didnt throw it away.
      • AjitN
        • Mar 2009
        • 287
        Sir I agree with you. But I have not used original sleeve from Ricoh. Counter is just 4.5 k.
        That's why I want to know specifications of fuse. Customer don't want to pay & was looking for alternative service provider. I had no better option
        • davel
          • Oct 2011
          • 1078
          Wire up a switch as detailed in many past threads.
          • AjitN
            • Mar 2009
            • 287
            Thank you all
            Problem got resolved by wired switch as described in many past threads
            • Lagonda
              • Aug 2008
              • 1649
              Greetings To All
              Regards
              For future reference its 0.125 amp ( or 125mA)
