MP-3350 faint copies great prints
  • aAandy
    • Apr 2012
    • 370
    [CQ] MP-3350 faint copies great prints
    hello everyone
    this machine prints well (except the dots, new drum going in) but copies come out rather faint - cleaned exposure lamp, reflector, mirrors, lens and CCD to no effect
    this is evidently a scanner issue, i will be returning to try some changes in SP4429, 4450, 4460, 4572 & 4585, but i was wondering if anyone has seen this before and can point me in the right direction
    attached first page is a print, 2nd a copy
    thanks in advance
    Andy
    • 37652
    Re: MP-3350 faint copies great prints
    I do not see any mention of cleaning slit glass or platen glass.
    • davel
      • Oct 2011
      • 1109
      Check again that the mirrors are clean.
      • sandmanmac
        • 3990
        Replacing Drum? Just the drum? NO.
        Replace/Rebuild the PCDU.
        Widely known issue (have a look through the site) that these PCU's often behave in this manner when they approach/ exceed the PM.
        "Yes", I know it doesn't make sense since the copies are good.
        Service and calibrate the PCU PROPERLY and the issue will be resolved
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Fit a new PCDU.
          This series is notorious for this symptom and a new PCDU is the resolution.
          • aAandy
            • Apr 2012
            • 370
            opsies - naturally i cleaned both before cleaning the lamp, reflector, mirrors, lens and CCD
            • aAandy
              • Apr 2012
              • 370
              i don't need to check, when i clean something, it is spotless else i do it again til it is
              • aAandy
                • Apr 2012
                • 370
                yes, i've read all the threads, and i've seen this issue before where a new PCDU did not correct the issue (machine replaced) - the PCDU in this machine is relatively new and the fault occurred 'overnight'
                not to mention i've been doing this for more than 30 years, so i posted because this was outside of normal
                • aAandy
                  • Apr 2012
                  • 370
                  thank you everyone for your responses, it is very much appreciated - i will be revisiting this machine Monday and i have a new PCDU so i can eliminate that possibility
                  sadly, a new lens assembly (CCD assembly) costs the client around $900.00 here - so i will fiddle every possible SP mode adjustment before going there
                  will post the solution in due course
                  • BLADE
                    former propeller tester
                    • 478
                    I reckon the 'good print' is poor and needs fixing before looking at the poor copy
                    • Brianneoe
                      • May 2015
                      • 322
                      This is not really a fix but it got me out the door and also a upgrade after the lease ended. After getting my Ricoh DSM out to look at the machine {we played around with a lot of SP4xxx settings to no avail}and changing out the CCD, what i did was to simply set the lite/dark setting to where the customer accepted the quality. Went into "program as default" and locked it in. Your sample shows a drum unit problem and after you do a PM and or change out the unit your quality will improve but will still be lighter than the print. My customer is a accounting firm so any documents where the numbers looked broken up on a copy was a problem. Your customer may not be so picky.
                      Good luck
                      • copyaction
                        • Oct 2007
                        • 991
                        • tufbnme
                          • 493
                          Laser unit, don't ask me why. Seen it, racked my brain over it. Replaced all of what you are thinking and finally tried the laser unit and that is what fixed it.
