Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    white lines thru the black printed copies only. drum and developer unit just changed not to long ago
  • francisco
    • Nov 2009
    • 168
    Re: Ricoh mp c5503
    clean the laser window
    • heath03
      • Jul 2018
      • 80
      Re: Ricoh mp c5503
      i have tried that. ill do that again
      ty
      • Notrons
        • Apr 2016
        • 71
        Re: Ricoh mp c5503
        If cleaning the shield glass didn't fix it, then you have a contaminated developer unit. I have had the same issue with MP C4503's with bad toner. I removed the black toner and it sounded like it was full of rocks. If that happens, the toner and the developer unit must be replaced. Before the new Dev Unit is intalled, the toner hopper must be cleaned out of all old toner.
        Good Luck.
          Re: Ricoh mp c5503
          what type toner? OEM?
          what do color prints looks like??
          these are PRINTS and not copies right?
          did you check the belt?
          is something blocking the laser > drum?
            • 37491
            Re: Ricoh mp c5503
            Worst case scenario is you have either dust or toner inside the laser assembly.
            • NeoMatrix
              Senior Tech.
              • 3513
              Re: Ricoh mp c5503
              Fault looks like Dev void toner clumps in the new PCU. I've seen it a few times from other model machines.
              I've seen brand new PCU's straight from the main supplier with dev lumps.
              Probably caused from storing warehouse supplies/parts in a hot environment.
              What's it like duplex on the second side?
              Place a blank sheet of paper half over the platen glass and do a half page (K) sky shot
              HTH
