SP 5200s
  • ABS tect
    • Sep 2013
    • 511
    SP 5200s
    Can't get this machine to scan for the life of me...ive saved several past forums but cant seem to find the magic thing i need to change.
    Interface settings list matches to another machine that can scan (another 5200s)
    I did SP 5-832-001, 5-801-10,11 5-846-046
    Network Security level set to 1, http is up, ipv4 is active.
    Any ideas why it wont scan? I am scanning to folder on windows 7, it is just this printer so i know its not the computer or network.
    Thanks in advance!
    Re: SP 5200s
    Thanks in advance!
    does the machine have access to that folder?
    what method are you setting up the scan?
    can you ping the machine from PC?
    • tufbnme
      • 493
      Re: SP 5200s
      Is the firmware the latest version? Also check to be sure the SMB workgroup name is the same.
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: SP 5200s
        DHCP network or fixed IP network ?
        Are using DHCP and host naming on the printer or fixed IP address?
        Have you deleted the share directory on the PC and forgot to set the file share directory access = Everyone ?
        Check you have the correct password in the printer address book which should match the PC user password.
        I assume the PC firewall is set to allow file and printer sharing.
        Are you using Domain , Public or Private firewall settings?
        Netbios port 445 is turned off?
        Does the printer have a print/scan SD-card ?
        Don't forget to power down and reboot to enable settings.
        • sandmanmac
          • 3981
          Re: SP 5200s
          Can you scan to your own Laptop?
          I seldom attempt new setup on a customer's network, until I know for sure it functions properly outside of it.
          • ABS tect
            • Sep 2013
            • 511
            Re: SP 5200s
            Workgroup name is the same
            Fixed IP
            I can ping it from my computer
            Firewall is turned off
            Folder is shared with everyone read/write
            Firmware is up to date
            the 5200s doesn't have scan/print cards on them like the mp 201 (at least in my experience, ive had several setup to scan without the print/scan sd card)
            It is not the pc or network...i have the machine in my shop with my personal computers. Another 5200 right next to it can scan and they both have the exact same information programmed into them as far as the address book is concerned.
            • tufbnme
              • 493
              Re: SP 5200s
              Get a boat, you have the anchor.
              • keithxxiii
                Just a tech
                • Nov 2014
                • 469
                Re: SP 5200s
                what does the log say in web image monitor? have you checked the smb version it uses?
                Aye! Cut the crap
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Re: SP 5200s
                  Both NIC lights are active?
                  Try resetting the NCS through SP mode.
                  If not you have a dead NIC.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    Re: SP 5200s
                    Have you checked to see if the SMB v2/v3 firmware is installed? rfg078851 is the file name (released 05/10/2018). With recent Micro$oft updates, SMB v1 has probably been disabled on your computer...but the other device in your office has the firmware updated already,
                    • luca72
                      • Oct 2017
                      • 1784
                      Re: SP 5200s
                      Thanks in advance!
                      I also think as guitar9199 would seem that the smb1 has not been used for more than 15 days is disabled, check in "activate / deactivate windows functionality" now I have no win10 in front, but basically: smb1 = on and remove the flag from " disable if not used "... since you say that on the other side by side with the same settings works.
                      "I'll be back"
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        Re: SP 5200s
                        Having a similar issue with an SP5210SR scanning to 2 new win 10 pc's.
                        Check that the network settings are set to "Private" on not "Public".
                        MY issue does seem to be SMB v1 on the new pc's as 2 other pc's can scan to folder.
                        If I can't get around it it'll be FTP scanning for this customer
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Re: SP 5200s
                          I have this issue also on a mpc2050. One lap top ok, other lap top no!
                          I even posted it here, but can't find it anymore...
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Re: SP 5200s
                            Also with windows 10
