Rocked up toner in developer unit
  • gregm27
    • Mar 2018
    • 15
    I had a bad toner cartridge that contained rocked up toner. This got in the development unit and causes multiple white lines on copies. What is the best way to get the toner rocks cleaned out of the developer unit? This is a Ricoh mp c4503
  • Polarbear
    • Feb 2012
    • 1070
    Re: Rocked up toner in developer unit
    You can use a fine sieve. It does not matter that it is metal as the developer itself is not magnetic. We have used this method multiple times with machines that had clots develop in their toner like the mpc305.
    Sent from my SM-G950F using Tapatalk
    Press the GREEN button!!
    • Notrons
      • Apr 2016
      • 71
      Had the same thing happen to 2 of our MP C4503's. The only fix is to replace toner bottle and dev unit. Just remember to clean out the toner hopper before you use the new dev unit.
      • fshead
        • 2365
        I dont know,i get change the toner bottle,,a given but dev unit for clumps..
        Unless you ran it to the ground and scratched the mag roller and destroyed all the auger roller seals,
        I say dump the unit on a big news paper and use a sieve or fine screen..
        there are some aftermarket bags of developer you could try to..
          • 37379
          One if your wife's silk stockings might work. Or a nylon if she doesm't have silk.
            • 22999
            If it's just one or two larger rocks ... no big deal. But if it's hundreds of small partially fused developer/toner stones, it's nearly impossible to get them all. =^..^=
            • jonhiker
              • 661
              We usually just replace the whole DV unit... saves a whole bunch of time and less mess
              • Polarbear
                • Feb 2012
                • 1070
                Or you could change the "belt".
                There are many to chose from below VVVV Lol!
                • sprinter
                  • Jul 2010
                  • 9
                  Rocked toner from bottle is a different ball game.I believe that replacing a development module is one part but it is equally important to be sure of toner pump.If rocks have found their way into the pump or its delivering pipes it will get choked and can make the replacement of the development module exercise an inefficient process.
                  If i were you,I would check the function of the pump and its toner delivery before the Development module changeover.
                  Thanks for reading.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    I think it is usefull to carefully instruct the customer to shake the toner botlle well enough before replacing it:
                    "Double so much as you would do spontaneous, miss Spencer..."
                      Aneurysm we have another spammer!
                        • 37379
                        Phil did you click the black triangle at the bottom left of his post to report it? I did when he first posted it.
