ricoh 3352 SC411 error
  • mkdirs
    • Oct 2014
    • 177
    any help with SC411 error
    i replaced the image unit with new one sam code
    also the charge roll and the fuser
    I think some thing with the separation
    thanks
    Xerotk.com
    xerox copier technician
    • 37533
    Re: ricoh 3352 SC411 error
    Have you tried looking in the service manual? If you had you would have seen the following.
    Separation bias leak error
    A separation bias leak signal was detected.
     High voltage supply board defective
     Discharge plate defective
    1. Check the harness of the high voltage supply board.
    2. Replace the high voltage supply board.
    3. Replace the discharge plate.
      wow you meanie! you really EXPECT someone to USE the TOOLS given to them to do their job?
      • copyaction
        • Oct 2007
        • 991
