Ricoh MP6002 - sc320-01
  • daveh12
    • Jul 2012
    • 157
    [Error Code] Ricoh MP6002 - sc320-01
    Hi all,
    Any help with this issue is greatly appreciated. The above machine constantly codes out to the code listed. Recycling the power clears the error until you run another job and after the last sheet it codes to sc320-01 within 3 seconds.
    Firmware is the latest, have replaced Dev power pack, and Dev unit. Worked fine for 2 days then back to square one. There was a similar thread on this posted a few years back where the electrode copper connections were replaced at the rear of the machine and this fixed that problem however no such luck for me after I replaced them
    Checked with ricoh support and as of yet have no suggestions.
    And help please would be great.
  • anothertech
    • 1766
    Re: Ricoh MP6002 - sc320-01
    Have you replaced the black plastic "bracket" pn B065-1137 which houses the drum shaft support bearing?
      • 37450
      Development output abnormal
      The high voltage applied to the development unit is detected 10 to be times higher than the upper limit (45%) of PWM.
       Development power pack defective
       Development bias leak due to poor connection, defective connector
      Check all connectors to the HV power pack.
      • daveh12
        • Jul 2012
        • 157
        Apologies for the slow reply. One of those weeks. Yes this was replaced with both copper connectors but the issue remained.
        • daveh12
          • Jul 2012
          • 157
          Connections are solid and copper connectors were replaced. No change.
