MP6054 Fuser
  • Marwanalhajbi
    • Jul 2018
    • 72
    MP6054 Fuser
    i have an issue no heat enough on printed paper,that leads toner to be removed,also a small black spots on the top?!!
    also, should LEVER PRESSURE RELEASE FRONT on fuser unit be closed or released??
  • keithxxiii
    Just a tech
    • Nov 2014
    • 469
    Re: MP6054 Fuser
    what troubleshooting steps have you tried?
    Aye! Cut the crap
    • Marwanalhajbi
      • Jul 2018
      • 72
      Re: MP6054 Fuser
      t of
      ive checked the drum unit,also fuser after that, i checked the tem of fuser i found all normal
        Re: MP6054 Fuser
        in SM... did you WATCH the fuser heat up? what were the temps?
        are you using OEM toner? that could be it too
        • keithxxiii
          Just a tech
          • Nov 2014
          • 469
          Re: MP6054 Fuser
          whats the total counter now? is the fusing sleeve in good condition? can you attach an sp data so we can investigate further?
          Aye! Cut the crap
          • davel
            • Oct 2011
            • 1107
            Re: MP6054 Fuser
            Is it set to the correct weight of paper being used, if not you will get these issues.
