Thermopile for MPC 2004
  • AjitN
    • Mar 2009
    • 287
    [Electrical] Thermopile for MPC 2004
    Team
    I need thermopile unit for MPC 2004.
    Machine is giving error code 442-02
    Has anybody replaced it? Is it available somewhere, here we are getting only complete fuser assembly
    Regards & thanks in advance.
  • fshead
    • 2356
    Re: Thermopile for MPC 2004
    Originally posted by AjitN
    Team
    442 is not fuser related...ITB related
    SC No.
    Level
    Error Name/Error Condition/Major Cause/Solution
    SC442-00
    D
    ITB Lift Error
    Even though the ITB contact and release motor (also Toner supply motor
    (M)) rotates, the ITB contact and release sensor failed to detect the
    specified sensor feeler status within specified time.
    Contact/separation operation: If not detected in 2000msec
    Sensor dirt
    1. Reset the Image transfer unit properly.
    2.
    Clean the ITB contact and release sensor
    3. Check the harness (disconnected, loose connectors)
    4. Replace the ITB contact and release sensor
    5. Replace the image transfer unit
    6. R
    • AjitN
      • Mar 2009
      • 287
      [QUOTE=fshead;716988]442 is not fuser related...ITB related
      Sir
      Thank you for your quick response & extremely sorry for my mistake.
      It is not SC 442-02 it is 542-02 - "
      Thermopile (Center) does not reload"
      Sorry again & looking forward for some suggestions / inputs from all
      Regards & Thanks again
      • jonhiker
        • 661
        On this model, the thermopile is located on the frame behind the fusing unit. When you pull out the fuser, you will see them
        • mj151
          Team
          sir ,
          is your issue resolved ,i have same issue please help me
          • JDYAL
            • Sep 2008
            • 186
            Sometimes the thermopile just needs to be cleaned of debris, if that doesn't work replace it and reset the the code in service mode.
            • anothertech
              • 1737
              It's a rare day that a thermopile goes bad. Probably a problem with the heat sleeve or thermistors.
              • JDYAL
                • Sep 2008
                • 186
                I agree that its most likely the thermistor or heat sleeve however I have had a customer damage a thermopile by removing the fusing unit and attempting to self repair the machine. Gotta love the wanna be techs.
