MPC2011 Noise
  • gnr115
    • 11
    MPC2011 Noise
    Hello
    I have two machines MPC2011 with this noise. It happens in the morning or when the machine is out of work for a long time.
    Please see:
    YouTube
    I already tested the fusing unit. The machines have about 5,000 ptints.
    What will it be?
    Re: MPC2011 Noise
    Originally posted by gnr115
    Hello
    Please see:
    YouTube
    What will it be?
    have you run the motor/fan test?
    what have you tried?
    • imi1953imi
      • Sep 2019
      • 8
      Re: MPC2011 Noise
      hello...there
      we have a problem of the plastic spiral toner coil breaking in more than one machine in this model mpc2011 please
      let us know what could be the real problem and how it can be fixed...
      regards
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: MPC2011 Noise
        The toner pump coils? Are you using original toner?
        Hit it.
        • imi1953imi
          • Sep 2019
          • 8
          Re: MPC2011 Noise
          Hello...there
          We use the original toner
          regards
          • FrohnB
            • Jul 2017
            • 1919
            Re: MPC2011 Noise
            Originally posted by imi1953imi
            hello...there
            regards
            It's an issue that is widely known. They are just crappy parts put in during production. Only thing to do is replace the sub-hopper that is affected. Pretty easy job.
            We've also had a couple machines where the waste toner transport coil breaks, and backs up into the units. This occurrence is much more of a pain in the ass, and usually have to replace Development units along with it, or you'll just keep getting issues going forward.
            Omertà
            • Trevorw
              • Feb 2020
              • 3
              Re: MPC 2011 Noise
              Good day , did you manage to find out where the noise is coming from ?
              As I have the same problem. Its only in the morning.
              I have checked all drum units and dev units, aswell as fuser gears and ITB.
              In sp mode I have ran the output tests on the drum motors, developer motors,fusing fan and fuser motor.
              Could the fuser idling settings resolve this issue?
              SP1-121-001
              SP1-121-002
              SP1-121-003
                • 37553
                Re: MPC 2011 Noise
                SP1-121-001
                SP1-121-002
                SP1-121-003
                Bad day for you. Did you not notice that this thread was started over a year and a half ago and last posted to almost a year ago? We call digging old post grave robbing. Go away grave robber.
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: MPC 2011 Noise
                  SP1-121-001
                  SP1-121-002
                  SP1-121-003
                  Ok, since you ran output modes, which mode caused the noise? And did you already try to adjust fuser idle settings?
                  NEVER ASSUME ANYTHING
                  • Trevorw
                    • Feb 2020
                    • 3
                    Re: MPC 2011 Noise
                    clearly you dont know what the issue is "key board warrior"! and what is the problem with posting on this thread?
                    • Trevorw
                      • Feb 2020
                      • 3
                      Re: MPC 2011 Noise
                      thats what boggles my mind, when i ran the output tests there is no noise , i have not tried the fuser idle settings yet and will be doing that today and will let you know if that solved the issue.
                        • 37553
                        Re: MPC 2011 Noise
                        Quick question, does the noise occur when paper is being pulled from a paper tray. If so, the friction pad is vibrating in its guide. There is a bulletin that covers it.
                        • davel
                          • Oct 2011
                          • 1107
                          Re: MPC 2011 Noise
                          Wrong model.
                            • 37553
                            Re: MPC 2011 Noise
                            Originally posted by davel
                            Wrong model.
                            If it uses friction pad type paper separation, the same principle applies.
                            • copier tech
                              • 8188
                              Re: MPC 2011 Noise
                              SP1-121-001
                              SP1-121-002
                              SP1-121-003
                              If your noise is the same is the original posters youtube clip it is caused by the cleaning unit.
                              Its a friction/vibration sound where the blade contacts the belt. Once the cleaning unit and/or belt age they make this noise & need replacing.
                              It's usually an intermittent noise, the customer will typically report the sounds comes & goes throughout the day.
