copy quality ricoh mp6500
  • CANCOUNTRY TECH
    • Aug 2008
    • 114
    hi all i have a strange one.MP 6500 intermittingly on photocopies blurs image so same text line is underneath words dosent happen all the time very intermittent fuser PCU all fine.Any idea would be apperciated
  • Polo-022
    • Sep 2007
    • 486
    Energize tray heaters and drum heater.
    Turn 3-903-1 SP from 0 (default) to 1. (Read Service Manual to confirm why..). Ask if this happens on "early morning copies" only.
    Good luck!
    • z_ming
      • Jul 2011
      • 31
      Re: copy quality ricoh mp6500
      i have the same problem with MP 6000 .every 250k copies it will happen .we just change the drum and brush ,it works fine .but according to the pm list drum would be 800k.that's really bother me a lot .
      any advice i'll appreciate
      • Smee
        • Aug 2009
        • 178
        Laser diode? I know if you mix up the numbers that come on the laser diode sticker it blurs text - kinda like registration is out although its only one colour, black.
        • TonerMunkeh
          Professional Moron
          • 3865
          How come you don't change the blade?
          Hit it.
          • zed255
            How'd ya manage that?
            • 1024
            Make sure the screw that holds the drum drive pulley to the shaft is tight.
            • iMind
              Vacuum Cleaning Expert
              • Mar 2008
              • 1116
              sigpicWe can all Win, but at the end we all loose. Save the greyhound
              • Eric1968
                • 2458
                Parts Manual, PCU4, no. 8, AD04 1140 Cleaning Blade.
                • teebee1234
                  • 1670
                  x2, I had this once in the past on a similar model. Has to do with the dual beam used for printing, copying only uses a single beam. Wasn't a blur but a duplicate, overlapping line of text.
                  • pocket aces
                    Ricoh Technician
                    • Nov 2008
                    • 72
                    X2 for the drum drive pulley
                    • teebee1234
                      • 1670
                      A slipping drum drive pulley will give you a stretched image. I believe he's saying that he's getting a duplicate line of text, which in my case was due to the dual beams misaligned intermittently. Replacing the laser diode fixed it.
                      • z_ming
                        • Jul 2011
                        • 31
                        sorry my bad english,actually i did replace the blade. 250k is not accurate. the image is like something wipe the paper ,
                        so it may have missed words
                        • withnail
                          • 59
                          Try replacing the memory Dimms.
