Ricoh MP6001, double-sided copying ( Single pass Document Feeder )
  • mterrero
    • Sep 2011
    • 60
    [CQ] Ricoh MP6001, double-sided copying ( Single pass Document Feeder )
    Ricoh MP6001, when two side copying on the DF ( single pass ), the image on the back ( Sometimes ) goes out unreadable, ( please see example attached ), when you turn off and on the machine, the problem es solved. Some idea, whats going on ?
  • mincopier
    • Dec 2015
    • 289
    Re: Ricoh MP6001, double-sided copying ( Single pass Document Feeder )
    The single pass feeder has a CIS module in the feeder. Reseat the connectors and if it continues replace the CIS.
      • 37477
      Also check the springs that press the white reference roller against the CIS, The text on the first page appears as if one side is not held fully in contact
      • Mark Bbb
        • Jun 2012
        • 1662
        condens?
        • Lagonda
          • Aug 2008
          • 1649
          My vote is for a problem with the CIS, but be warned they are very expensive.
          • fshead
            • 2376
            I would shake the adf upside down and check for wandering paper clips,staples etc that
            can short or ground the adf.
            I always am amazed of how stuff finds its way inside them..
            • vargue
              • Oct 2011
              • 404
              usually this happened in feeder cable or ground terminal
              • DRichard
                • May 2008
                • 482
                I wouldn't rule out your HDD...
                "Enjoy every sandwich."
                -- Warren Zevon
                • mikadonovan
                  • May 2008
                  • 2931
                  I had a 2nd side CIS blur on this exact model. When I inspected it, I found some sort of greasy lubricant coating the rear side of the assy. Cleaning it took care of the problem. Also, make sure the springs on the underside ADF guide (the one you pull away to see the CIS) are applying even pressure.
                  NEVER ASSUME ANYTHING
