Control Panel Advise
  • steve1973
    • Sep 2013
    • 43
    Hi, I am considering changing my copier to a ricoh unit (mpc 4503,3003 or 2503zsp) and was wondering if the smart operations panels are any good? i had been planning on looking for a machine with the conventional 9" control panel as it seems to do the job fine and i imagine are more reliable, the zsp model panels look interesting but i am not 100% sure about how reliable they are compared to the 9" one, i notice that ricoh has changed them again on the latest model,has anyone had experience of panel faults?
    • 37357
    Re: Control Panel Advise
    The only problem I have had with an SOP was one that lost touch screen calibration. Had to do a full power down and reboot to correct it.
    • TonerMunkeh
      Professional Moron
      • 3865
      The Cheetah panels do, unfortunately, have their niggles. Set them to normal startup mode, keep on top of the firmware and ensure the machines are shut down correctly, never switched off by the plug. Boards and software are fried if that happens. I would get a machine with the second generation Cheetah panel too, the 04 colours.
      Hit it.
      • guitar9199
        • Sep 2016
        • 1100
        I've converted a couple of machines to SOP v1, and it's definitely a lot of "hoops" to jump though. If it's already got a normal operation panel and it's working, why mess with it.
        The SOP v2 panels on the 04 series and up is a different beast altogether (No hard keys at all), but I have had fewer issues with it than with the v1 panels.
        • steve1973
          • Sep 2013
          • 43
          Many thanks to all, very helpful advise.
          • icese
            • Oct 2012
            • 8
            I used to kick off the power plug and jump back when I restarted.
            Sc-554, SC-220-4 will appear after restarting, and then SC-995-4 will appear after re-booting, and then re-processing NV RAM and Control Panel data will solve the problem.
            • copier tech
              • 8132
              To be honest the SOP panels are no real improvement just one more coponent to go wrong!? However they do make the MFD look nice!
              • fshead
                • 2360
                and as or if even a tech, WHY would you do that.........why not drop in a river and try to retrieve it and run i.....
                • Lagonda
                  • Aug 2008
                  • 1649
                  Still haven't worked out why anyone would want to access the interweb from their photocopier op panel, wouldn't it be easier to do it from your desk PC with a nice big screen and a mouse?
                  But back on subject, if your SOP does die they are very expensive to replace.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    I use the panel browser to access the WIM when I'm setting up @Remote
                    I believe the original idea was so that customers could print directly from a web server....still a clunky thing to do.
                    • steve1973
                      • Sep 2013
                      • 43
                      Yes the web access does seem to be a bit of a gimmick ,suppose some people may find it useful? ,looking like the 9" panel is a better option, i'm really comparing chalk and cheese anyway, this upgrade will be from the best machine canon made (just kidding) the ir3180
                      • copier tech
                        • 8132
                        I agree the IRA C3180 is a great box mate of mine still puts them out on contract!
                        • 8T2
                          • Aug 2015
                          • 257
                          Only real issue I have come across with the android panels are that the brightest setting isn't bright enough if there is too much sunlight in the office, but this is probably more of a problem for us guys in the Southern hemisphere
                          Sent from my ALE-L02 using Tapatalk
                          • Batman1976
                            • Jun 2016
                            • 88
                            04 Range have the better SOP but as previous post say if they become faulty or damaged they require the complete panel to be replaced and they are not cheap!!!
                            • copier tech
                              • 8132
                              Go into screen features turn off auto dim, set brightness to max that's what I do on all new installs.
