ricoh 1060
  • hodgiepodgie
    • Jul 2008
    • 284
    ricoh 1060
    i am getting dark background and an error codes of sc 355,353,351.dark background sometimes i can reset by using sc3001/2id sensor .could it be pot sensor is bad or i.d sensor .leaning towards pot saensor ricoh 1060 550 k copies
  • scully
    • Mar 2006
    • 46
    More Info would help , such as Meterage and last PM Service ,or is it due ?
    (PM 300K}
    John
    Uk
    • hodgiepodgie
      • Jul 2008
      • 284
      dont know how much more info you need pm was appx 300k ricoh standards for 300k.gray background if i remember could be pot sensor.can clear temporarily with sp3001/2 or drum cond
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        I'd start with the maintenance parts before you throw sensors, boards, etc at the machine. Even if the machine hasn't reached the maintenance cycle, the parts can fatigue just by being in the machine.
        • totoro
          • 568
          If you have already changed the developer then I would go for the drum next. I went around and around with a 1075 and changing the drum ( even though it looked ok )took care of the background.
          Totoro
          • scully
            • Mar 2006
            • 46
            Agree with other posting , try Drum as you have replaced Developer
            Resetting Sensor is only masking problem !
            John
            Uk
            • Lagonda
              • Aug 2008
              • 1649
              Been caught with something simular on this model copier before. Tech swapped the drum in and out so quickly that the fuser didn't get below the tempreture trigger point for for the copier to go into process control. Copier then started producing copies with all its values set for a worn out drum. Customer never turned the copier off so it never went cold and auto processed controlled its self on start up. Result was a very confused tech a copier that gave worse copies then before he PMed it.
              Ran SP 2962 Forced Auto Processed Control and it all came good.
              • hodgiepodgie
                • Jul 2008
                • 284
                ok will give a go .will let you know.tanks again all.
                • hodgiepodgie
                  • Jul 2008
                  • 284
                  Ok developer replaced no change.will replace drum and do 600k pm.then will let you all know
                  • hodgiepodgie
                    • Jul 2008
                    • 284
                    well not sure if it was drum but did pm w/drum corona wire and grid,problem solved.thnks again one and all...
                    • pro.b.unal
                      • Dec 2008
                      • 42
                      arızalarının geneli ID sensor voltaj yogunluklarını algılayamıyor.Eger drum corona ünit cl.balade ve Cleaning seal yüzeylerinde bir problem gözükmüyorsa ve yakın zamanda değişmişse benim size önerim drum shuft'ının makinenin drive systeminden ilk gücü aldığı dişlinin arkasında bir rulmam bulunur. bu rulman drum'ın topraklamasını sağlar. Zamanla rulman içerisinde iletkenlik bozulunca drum yüzeyine topraklama voltajları uygulanamaz ve copyanın zemininde siyahlık oluştuğu için ID sensor okumaması gereken yerde yogunluk görürse bu sorunlara sebep olur. Rulman 1N6001 tipi bir rulmandır
                      iyi çalışmalar
                      • schooltech
                        School District Tech
                        • Jun 2008
                        • 504
                        Those are some cool dongle adapters hanging off of some of those letters.
                        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
