MP3054 Disordered image
  • GeorgeBest
    • Jul 2009
    • 505
    Hi,
    This problem as you see on the image appears mostly on the first print !
    When printing large jobs no such problems, only the first . . .
    Happens couple of time during the day. . . .
    Changed the PCDU unit, no result.
    Anyone?
    Thanks in advance
  • mikadonovan
    • May 2008
    • 2936
    Re: MP3054 Disordered image
    I think you may have 2 tiny people living inside the machine that are missing their right hands. Definitely a problem. I seen this a few years ago on a B&W 2075, although the dark blur was imaged across the entire document. It turned out the drum drive flywheel (stabilizer) was missing causing jitter. I suppose loose/worn components in the drive/paper feed system could be an issue. First glance you would think a PDCU problem, like dev unit gears or charge roller issue, but you have indicated that has been replaced.
    NEVER ASSUME ANYTHING
    • copier tech
      • 7931
      Originally posted by GeorgeBest
      Hi,
      Anyone?
      Thanks in advance
      [ATTACH=CONFIG]41370[/ATTACH]
      What is the main counter on?
      • GeorgeBest
        • Jul 2009
        • 505
        300K.
        • copier tech
          • 7931
          Hi,
          Anyone?
          Thanks in advance
          So you have changed the PCDU drum & dev. Not much left PTR!?
          Does or happen on all trays inc bypass?
          • zed255
            How'd ya manage that?
            • 1025
            Could be fusing sleeve assembly. I have seen them cause jamming or image quality issues when the internal pressure pad dries out making the fuser sleeve difficult to turn.
            Was the 240k PM performed? I have had good luck with making yield on this series but the fuser doesn't do well when pushed further than stated yield.
            • keithxxiii
              Just a tech
              • Nov 2014
              • 468
              I suggest recreating the problem by printing or copying first page. Upon passing thru the drum, open the right cover to find out where the problem is coming from. It can be PCDU, PTR, or even the Fusing.
              Aye! Cut the crap
              • GeorgeBest
                • Jul 2009
                • 505
