Ricoh MPC2050 SC542
  • Spar
    • Jan 2019
    • 32
    [Error Code] Ricoh MPC2050 SC542
    I have this service code and have done following:
    1. Changed Heating roller thermostat
    2. Changed pressure roller thermostat
    3. Changed front thermistor.
    Still hace SC 542, not bale to reset. It is asking contact administrator. Please help help?
    • 37376
    Re: Ricoh MPC2050 SC542
    You might have an open heating element.
    • Spar
      • Jan 2019
      • 32
      I checked heating elements by putting power directly to them, both are turning on,
      • Spar
        • Jan 2019
        • 32
        what should be reading of these Thermisters at room temp.?
          • 37376
          Normal room temperature reading should be 25 to 27 degrees when checked in System SP display temperatures.
          • solorajder
            • Jul 2010
            • 106
            Did you reset SC code in SP mode?
            Sent from my G8441 using Tapatalk
            • Spar
              • Jan 2019
              • 32
              yes it came back with SC547
              the fuser unit is not getting power form the power supply Board.
              • davel
                • Oct 2011
                • 1095
                That sounds a bit dangerous.
                • fshead
                  • 2361
                  i think most of must would just meter out the heating lamps.
                  You might need a point to point to figure if you have a power supply issue versus a controller issue.
                  does the fuser attempt to warm up at all,is it ice cold or warm after coding out/.
                  • Spar
                    • Jan 2019
                    • 32
                    Fuser does not attempt to warm up atll.
                    After I reset the sc code , it came up with SC547, whcih is pointing to power supply. There is no ourput power to the heaters of the fuser unit, looks like the relays are not commanded by the control unit to turn the heaters on. Do you know how the commands are generated to turn the power on to the heaters of the fuser unit?
                      next time I would recommend getting your OHM meter and check continuity on each lamp... disconnect from the lamp contacts first...
                      then try the thermistors...
                      hold the thermostats in you hand for a min ( out of fuser ) then read with meter.
                      ANY open ..replace that part
                        look in SM.. Theory of Operation.. Fuser Section.. that will give you the path of the signals ..timing... and which part of the fuser requests power.
                        did you check for pinched/broken wires?
                        Start with backtracking your work ( after reading manual suggestion ) via disassembly
                        Perform the suggested check on components.
                        Check connection between fuser and machine.
                        reassemble and test
