scanning large files (c2503)
  • Mark Bbb
    • Jun 2012
    • 1662
    Scanning big files:
    Is it true that scan to folder can handle bigger files than scan to email?
    Which settings or manipulations must be set to assure good transmission of big files?
    Thanks in advance...
  • Kimi
    • Feb 2018
    • 105
    Re: scanning large files (c2503)
    Scan to email will always have a max email size so the restrictions is there not at the copier.
    I dont believe there are any settings that you are looking for.
    • sandmanmac
      • 3985
      While I agree with this point to an extent, he may not be aware that the copier's default setting is 2048Kb (which is stupid and unrealistic) so I always turn off "Max email size" in scanner features.
      Also while there is a limit to the size of email that can be transmitted depending on the mail server, it's still going to be at least 20-30Mb or more, which is pretty substantial as long as the Resolution is set at a reasonable level.
      • guitar9199
        • Sep 2016
        • 1100
        Most web based mail clients I believe throttle their email to a MAX size of 10 Meg. I'm sure there are some out there that do more...but that's usually what my default Key Op training says.
        Another thing to look for on Savin/Ricoh is to make sure you turn OFF the "Divided Email" feature. Gmail especially hates that....if it sees a stack of emails coming in one right after another, it usually just blocks everything after the first one!
        Good luck!
        • Dan G
          • Nov 2014
          • 56
          Originally posted by Mark Bbb
          Scanning big files:
          Scan to Folder can definitely handle more as it has no limit other than machine memory. to keep scan to email files smaller teach customer or set as screen default Auto Color Select. Because if they choose scan in color, all pages are scanned in color and the file is huge in comparison
            • 8195
            Good luck!
            You can also turn on pdf conpression this makes a huge difference to the scanned file size.
              • 37560
              If you have an in house Exchange Server, your IT can change the max internal email size.
              • Mark Bbb
                • Jun 2012
                • 1662
                i scanned both to folder AND to email.
                With scan to folder the mpc2500 stopped (without any message) and didn't send the file.
                With scan to email, i received the email with message "part 1/5". But the c2500 told me to reload the last 3 pages (on top off the papers that were not yet scannedl).
                So, we don't think scan to folder is an improvement.
                Is it possible to send a file (with a scanner) directly to "we transfer"?
                • ridgemill
                  • Sep 2017
                  • 191
                  Either download the custom SMB3 firmware, or use FTP.
                  Turn on all compression settings, set all compression to maximum, and turn off Divide & Send and Max File Size: under User Tools > Scanner Features > Send Settings.
