MPC6003 Jam code 001
  • Hadster
    • Aug 2011
    • 264
    I have run into this on older machines with door switches but this doesn't seem to be the case as of yet. Has anyone run into J001 on these machines yet? Thanks for your help!
  • anothertech
    • 1762
    Re: MPC6003 Jam code 001
    Does it show where the jam is? I read about a machine showing J-001 also showing jam in C, turned out to be the interlock sensor on the duplex door was failing.
    • Coptech
      worker drone
      • 460
      I believe J001 is a jam at power on.
      • guitar9199
        • Sep 2016
        • 1100
        Stamp holder door on the ADF is probably open. Close it and you should be good to go.
        • Hadster
          • Aug 2011
          • 264
          Previously just checked continuity on door switches (checked ok). Replaced front and side door switches and all is well.
