Ricoh 6001 sc878
  • vargue
    • Oct 2011
    • 404
    [Error Code] Ricoh 6001 sc878
    Hi this code make me piss me off . Machine start up scanner lamp start moving and fusing unit working but panel show please wait in the beginning .I need clue .I don't ready for replacing New one.i don't have firmware
    I some one help
    Re: Ricoh 6001 sc878
    I some one help
    get manual.. look thru it.. you will need technical helping on site.
    • vargue
      • Oct 2011
      • 404
      I have service manual . تسدق بالله انا غلطان وكلفت اهلك وردت ليه
      • davel
        • Oct 2011
        • 1109
        I think you have made a toaster, probably need new controller and firmware, what did you do before this code appeared?
        • davel
          • Oct 2011
          • 1109
          did you put the Arabic phrase in to piss Phil B off?
          • keithxxiii
            Just a tech
            • Nov 2014
            • 471
            I can't help but use google translate into it.
            Aye! Cut the crap
            • Paper_Jam
              Expecting a call.
              • Jun 2007
              • 101
              Could be HDD unpluge HDD and see if it goes ready.
              • vargue
                • Oct 2011
                • 404
                Of cours I did but no luck .it's late for 3 minutes I tried to get to copy sp. it's opened then make hdd format but no avail.after format I closed sc819 revealed . I tried close 5985 network and usb set to 0
                • vargue
                  • Oct 2011
                  • 404
                  Nothing happened my customer unplug cable improperly way. My be current in his office unstable
                    no worries Mate, People are just that way. IT doesn't piss me off , it just shows that while in another's house they don't want to play by the rules... fine.... those types will no longer receive help from me.
                      WHY should we have to? ESP since they typed other messages out in English.
                      • vargue
                        • Oct 2011
                        • 404
                        Oh Mr Phil first I appreciated your help excuse me this customer make me crazy . We all her a big family .don't be sad from me
                          • 37641
                          Actually I used Google to translate. It is a Muslim curse. He cursed Phil B for his "get manual.. look thru it.. you will need technical helping on site." Phil should have merely asked "Do you have the service manual."
                            and then they turn around and LIKE my message. go figure!
                              but YET I should use Google to translate a CURSE directed AT ME? would a curse qualify as a reportable post? Hate speech ?
                              ALL I did was ASK if he had a MANUAL and instructed he might want to read it and get a tech in to help.
                              Screw it... bout tired of all the crap here too!
