MP C3000 RICOH QUALITY
  • stefatric
    • Jan 2019
    • 9
    qualcuno saprebbe dirmi il problema?
  • illude2
    • 30
    Re: MP C3000 RICOH QUALITY
    ITB Belt / Cleaner
    • fshead
      • 2376
      it wouldnt hurt to clean the reg roller tooo..
      • stefatric
        • Jan 2019
        • 9
        I have clean belt, belt cleaning unit and i changed cleaning blade drum Magenta/ Cyan.
        the belt is more less dirty.
        • stefatric
          • Jan 2019
          • 9
          Do you think i should clean the primary charge roller?
            you NEVER gave the PAGE count on the parts... I doubt just cleaning the ITB clean unit will get it... replace cleaning blade on ITB....
            are all the PM parts replaced on time?
            clean charge roller? no would be finer lines
              • 37532
              Don't clean the cleaning unit. Replace it.
              • Polarbear
                • Feb 2012
                • 1070
                Those cleaning units were notorious! When they went bad, no amount of time/effort could fix them. Bin them and replace with new!
                Press the GREEN button!!
                • luca72
                  • Oct 2017
                  • 1784
                  without a pm counter I can guess, 1) drum arrived at the bone, 2) itb cleaner
                  "I'll be back"
                  • stefatric
                    • Jan 2019
                    • 9
                    If it was the ITB cleaner, it would get the belt dirty with all the colors...Do you think it is possibile that the problemi is caused by both the drum and developer exhausted? Aiuto luca (conosci qualche fornitore di componentistica ricoh.Grazie )
                      • 37532
                      NO!!! Just just the cleaning unit exhausted.
                      • luca72
                        • Oct 2017
                        • 1784
                        then it looks like a pcu gone, how visually is the drum cylinder? the print seems to have squealed-tire over...LOL, you should also see on the drum that is all striped.we buy directly from ricoh italia (we are official sellers), however you can try the EET group, which however is in the UK, you find good prices, but there are times of shipping, i and my boss we have a warehouse in the laboratory with all the main parts of the models that we sold, if you want to follow those machines in the field you should have them ... or at least one used machine working to pick up the parts to try or waiting for spare parts
                        "I'll be back"
