Ricoh MP C4000 ADF image problem
Re: Ricoh MP C4000 ADF image problem
Tech has replaced IPU, Scanner assembly, SIOB. When I visited the site, i did a backup of the nvram, cleared it, did some test copies and works fine.
When data has been restored, the same problem came back.
It's pain when you have to set all the values from the Birth Certificate of the machine.
Just a friendly reminder tho, check your logging data if you have an SC code 1XX.Aye! Cut the crapComment
if I was referring to the lanes where the lamp and the crystals are ... if the adf has had weight on top you have to put it back again, taking it from where the glass is and pushing it up with your hands until you see that it is horizontal . that is the problem that you have insuranceComment
