mpc 3004ex with sc672
  • limo
    • Jun 2008
    • 103
    the code is generated in the morning after exiting from sleep mode.Replacing hdd reloading nvramdident help.will try controller.
    Anyone have seen that. only in the morning afer recovering from sleep mode
  • Zeldaman
    • Mar 2011
    • 946
    Re: mpc 3004ex with sc672
    Hi there!
    Dumb question: is the fw (package & module) up to date? There were some changes in the last 2 weeks. Also check the cables, especaly screen - controller.
    Greetings...
    • limo
      • Jun 2008
      • 103
      Firmware is uptoday.cables are reseated.Strange thing is the time of the occurance only after waking up from sleep in the morning
      • JDYAL
        • Sep 2008
        • 187
        Did you update control panel firmware?
        Last edited by JDYAL; 02-11-2019, 02:33 PM. Reason: was thinking a different machine
        • copier tech
          • 8192
          Try this setting had the same on an MPC305, stops the controller going to sleep.
          SP 5-191 to 0
          • JDYAL
            • Sep 2008
            • 187
            Sorry guys my morning coffee hasn't kicked in I was thinking a different machine. Copiertech has more insight to these codes definitely listen to his advice.
