c5503
  • T911
    • Jun 2007
    • 628
    c5503
    i can't get rid of this message "replace fusing belt now" i reset pm count, 3701, 7803, 7622, and it shows the new date in 7950. what am i missing
  • T911
    • Jun 2007
    • 628
    Re: c5503
    "fusing belt unit must be replaced now message"
    • copier tech
      • 8172
      Re: c5503
      Use SP3701 - xxx
      • JDYAL
        • Sep 2008
        • 187
        Re: c5503
        The manual just says 5810-002 3701-116. If thats not working you may have to use the "new unit detection fuse" that comes with the heat sleeve.
        • CopyBats
          • Aug 2011
          • 147
          Re: c5503
          Use SP3701 - xxx
          This
          If it works, don't touch it.
          • T911
            • Jun 2007
            • 628
            Re: c5503
            did 3701 and 5810-2 witch failed. the 02,s have the fuse not the 03's right
            • copier tech
              • 8172
              Re: c5503
              You don't need a fuse that is just for SC544 errors etc. SP5810-1/2 is to reset an fuser ERROR not a PM COUNTER.
              Depending on your firmware version when you first enter SP mode do you see a "PM Counter" tab? if so use that to reset the fuser sleeve AND pressure roller counters.
