MP C4503 Poor print quality
  • nodle
    • 142
    One of my coworkers is experiencing a problem with a MP C4503. The copies look good, but print jobs are not coming out properly. He has tried to replace the controller, IPU. HE swapped the transfer belt unit with another machine, and also swapped the transfer separation roller. He has been at they count 4 times and is currently stuck. I have attached a photo of what he has sent me. Any guidance or help on this would be greatly appreciated.
    • 37652
    Re: MP C4503 Poor print quality
    Did he check to see if Toner Saver is set in the driver?
    • nodle
      • 142
      [ Unfortunately it appears that whatever is going on is internal to the machine. As you can see from the Prince for color calibration.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Has FW been done?
        Silly question I know...and yet
        • TonerMunkeh
          Professional Moron
          • 3865
          Memory clear the printer app and ACC it. That should sort it out.
          Hit it.
          • nodle
            • 142
            Thanks for the input. I will be going out there today. I will keep everyone posted.
            • StephenB
              • Aug 2015
              • 246
              We had this same problem. Clearing the app and performing the ACC , and then choosing to go back to previous setting was the only way to get it to print quality again.
              This is "something" internal. Have the MP C 3002 as a parts unit and internal use.
                • 37652
                At one time Ricoh USA was recommending to run ACC after all firmware updates on the Cxx03 models. When doing so, I would notice that the previous settings were gone.
                • nodle
                  • 142
                  Thanks for all the help. that was the fix
