MP 7001 transfer unit solenoid strange one.
  • copytrust
    • Feb 2010
    • 118
    So this a strange one guys, i went to a machine Ricoh MP 7001 for a jam j14 and the paper was jammed on the transfer unit, there i noticed that if you cleared the jam the next job it doesnt matter if it one or a 1000 copies the machine will work fine, but if you wait 10 to 15 seconds the next job will jam again the same thing.
    i saw when the machine jams the transfer unit solenoid it dosent work so went to SP modes input and gave power, suprise suprise the solenoid its working fine,
    but when the jam happens the solenoind doesnt work
    The client has also a MP7500 so took the whole transfer unit from this machine, and its making the same pattern jam again and again one job the solenoid its working and the next one it s not.
    so i changed the door switches as a start, cleaned the two paper feed registration sensors no luck at all, i am thinking of chaging the main board (if i can find one availiable).
    Any ideas guys??
  • vargue
    • Oct 2011
    • 404
    Re: MP 7001 transfer unit solenoid strange one.
    may be overload in some units .yo said that yo swapped transfer unit to another machine.and some harness loosen. remember what happend in last visit.did yo check developer tank leaking. many questions
    • fshead
      • 2376
      does the problem follow the 7001 or the transfer unit,meaning when you swapped out transfer units did it fix the mp7001?
      • copytrust
        • Feb 2010
        • 118
        Yes I took from a Mp7500 the whole transfer unit put in on the mp7001 and the machines make the same pattern one jod is working the next job jams.
        Στάλθηκε από το G3412 μου χρησιμοποιώντας Tapatalk
        • TonerMunkeh
          Professional Moron
          • 3865
          Jams 12-14 is usually caused by the registration mylars.
          Hit it.
