Ricoh d158 - Distorted
  • printertnc
    • Jun 2015
    • 68
    Good morning
    I have a problem with a Ricoh 2501 SP (Black Model - Black Only Print).
    All prints and copies that come out are distorted by 2/3 mm.
    What can I do to correct this error?
    I can attach an example.
    Thanks for your support
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh d158 - Distorted
    Can you post the sample please, distorted doesn't really describe the fault.
    Hit it.
      • 37533
      Exactly what do you mean by "distorted by 2/3 mm"? Is it skewed? Is registration off, either side to side or lead edge?
      Are you a tech or a user?
        $$$$ to donuts end user!
        • luca72
          • Oct 2017
          • 1784
          Originally posted by printertnc
          Good morning
          hello, if I understand correctly the image is distorted (?), that machine has a laser protection glass hidden behind the plastic, did you clean it? it happened to me once not to have inserted it in all the length of the guide, and after all it was a little out, and produced distorted prints on one side, I do not know if it's your case.
          "I'll be back"
