mp 4002 light copies
  • miltiadisf
    • Jun 2016
    • 3
    i have change opc drum , clean blade , charge roller, developer. set bias too default first and make developer inti without the toner drop on devepoler unit. at first everything its ok. after 3000 copies i have light copies , the black is not so black . any help?
    i have clean id sensor and make force toner but the same. pls help me.
  • Zeldaman
    • Mar 2011
    • 946
    Re: mp 4002 light copies
    Hi there!
    Have you cleaned the magroller? My 1. guess is the tonerhopper. The 4 shuffle-mylars often get loose so the toner is partially blocked.
    Hope this helps.
    Greetings...
    • FrohnB
      • Jul 2017
      • 1919
      Did you forget to take out the clear toner plug (the one you insert into toner chute when you flip the Drum Assembly over)? I did this on one of my first PM's for this series.
      Omertà
      • luca72
        • Oct 2017
        • 1556
        besides everything you've done, clean all the lenses / mirrors inside the laser box unit: it's easy
        "loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa)
        • CopyBats
          • Aug 2011
          • 131
          How is the quality of the paper? Is it leaving a lot of dust? ( Cheaper paper tends to do that). Is your operating environment normal? ( Humidity, temperature etc)
          If it works, don't touch it.
          • MIGUELMARCHENA
            • Feb 2018
            • 174
            What toner are you using?
            a client used a few generics with which he gave this problem
            3500D is the jar that bothers
            when you put another mark it was solved
            As you have already explained, check the hopper, as the toner is caked in the toner output to the image unit and the copy is rinsed
              • 22808
              WTF HUH?
