Service codes SC 542 and SC552 on Rico MP C2050
  • Spar
    • Jan 2019
    • 32
    My printer shows the code SC 542, I changed all sensors in the fuser unit, same problem. I tested the heating Lamps both were working. Continue to show SC542, I reset te code many times keep on coming.
    I purchased a new fuser unit The service code changed to SC552.
    I Put a new power supply, Back to SC 542.
    I do not know where to go from this point?
    Please help.
    Re: Service codes SC 542 and SC552 on Rico MP C2050
    Originally posted by Spar
    My printer shows the code SC 542, I changed all sensors in the fuser unit, same problem. I tested the heating Lamps both were working. Continue to show SC542, I reset te code many times keep on coming. I purchased a new fuser unit The service code changed to SC552.
    I Put a new power supply, Back to SC 542. I do not know where to go from this point? Please help.
    This error is a fusing thermistor error, it can mean:
    The fusing lamp is not connected. Reconnecting it may solve the problem.
    Thermistor is bent or gone bad. You may need to replace it.
    Or, the thermistor position is incorrect. To try and reset the code press:
    Clear Mode, 107, Clear/Stop and hold for 5 seconds.
    you said you checked lamps and (sensors?) did you bother to replace thermistors and thermostats? you did replace bushings n bearings too right?
    the 552 on new fuser... did you make sure: you got the right voltage and model? ( some can fit from another model but code out )
    • solorajder
      • Jul 2010
      • 106
      Sent from my G8441 using Tapatalk
      • Spar
        • Jan 2019
        • 32
        First I changed evry thing two thermisters, and three sensors same rpoblem.
        Second I purchased new fuser unit, and installed, service code chnged to SC552.
        Third I chnged the power supply, service coode back to SC542.
        There is nothing left to be chnged in fuser unit, evry thing is new.
        Where to check now?
        • solorajder
          • Jul 2010
          • 106
          You didn"t answer on my question. Did you check a thermopile? Thermopile is located on machine and is not in the fuser unit. Look on picture I attached.
            • 37652
            Please help.
            You sound like an end user to. If that is the case, you have 2 choices:
            1. Call a Ricoh branch or dealer.
            2. Replace the dinosaur.
            Considering the facts that Ricoh discontinued Assured Parts Availability one year ago and Field Support six years ago, I would recommend choice 2.
            • Spar
              • Jan 2019
              • 32
              Based on what I did, looks like thermopile is the problem.
              How to access Thermopile?
              • Spar
                • Jan 2019
                • 32
                Looks like it is the thermopile,
                Please let me know how can I test it?
                or just replace it?
                What is the part number to order?
                Thanks for help.
                  or just replace it?
                  Thanks for help.
                  HIRE A DAMN TECH!
                  you don't seem to be qualified!
                  • Spar
                    • Jan 2019
                    • 32
                    HIRE A DAMN TECH!
                    We want to fix our self , the etch are charging just to come here $250 and 150 per hr after. More then the printer value. Please help us.
                    Thanks,
                      We want to fix our self , the etch are charging just to come here $250 and 150 per hr after. More then the printer value. Please help us. Thanks,
                      1) LEARN how the processes work!
                      2) PAY for a SM & PM
                      3) RTFM's
                      4) Learn the process for each section of the unit
                      5) Find a reliable source for parts
                      You end users think it is soooo fucking easy to do our job... that's why some techs crash n burn in the first few years... they ALWAYS try to find the ......." easy way out"
                      Ain't no such fucking bird!
                      • allan
                        RTFM!!
                        • 5462
                        Take slimsob's advice. A refurbished fuser is worth more than the machine @ about $360.
                        Almost think a toner is worth more than the machine!
                        Whatever
                        • Spar
                          • Jan 2019
                          • 32
                          I removed the Thermopylae and cleaned the lens, still the same problem. Thermopylae has a mrking B4214050 I assumed this is the part number, but it is not listed part number. Any body can help me what is the part number for the thermopile? so that I can purchse it.
                          Thanks,
                            • 37652
                            Thanks,
                            That is most likely because Ricoh has discontinue the part. Like I said before, replace the damned machine. It will cost you a lot less in the long run.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              Thanks,
                              You've already stated that you won't pay a tech to look at your machine...IN A FORUM FULL OF TECHS..!!!
                              You'll get no help here..keep on walking brother..!!!!
