mpc 4502 black color quality
  • anpetros
    • May 2011
    • 43
    [CQ] mpc 4502 black color quality
    hello everybody .I have an mpc 4502 which has problem with black.Toner is not evenly distributed on the paper and i have white or more blacked areas.Please see atachment for details.black pcu has 75k.Thank you all in advance for your help.
  • FrohnB
    • Jul 2017
    • 1919
    Re: mpc 4502 black color quality
    What's the count on Development unit? Count on Transfer/ Sep. Roller? Have you cleaned the laser glasses? All the colors look a little grainy.
    Omertà
    • fshead
      • 2376
      it looks very undertoned.
      maybe from sitting for a long time?
      has the machine been used?
      • logrady2331
        • Feb 2011
        • 301
        A worn out heat sleeve will give copy quality issues like this.
        • fshead
          • 2376
          i had a sleeve do that too but it also gave me small smudges......
          DO A SKY shot and stop it before fuser unit
          • anpetros
            • May 2011
            • 43
            117k black developer and transfer/sep.That's the total copy count .Yes i have cleaned the laser housing by removing it.Black is very grainy .Magenda has some grains also but not that much.
            • anpetros
              • May 2011
              • 43
              Yes the machine has been sitting for a long time but i made some....200 copies.nothing has changed.Did forced toner supply,several process controls,and cleaned laser housing as well as black unit.
              • anpetros
                • May 2011
                • 43
                I did a skyshot and...indeed.Unfused areas are ok.I cannot believe it.I will replace them and let everybody know the result.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  what are the total counters?
                  • JDYAL
                    • Sep 2008
                    • 187
                    Since the machine has been sitting for a while I would pull the pcdu's apart and clean the charge rollers. A good cleaning after a machine has been sitting for a while usually takes care of a lot of issues.
                    • anpetros
                      • May 2011
                      • 43
                      Color total 78997 and b/w total 43876
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        take out black pcdu and shake gently (keep horizontal!) 15 times (back and forth)...
                        Better?
                        • CopyBats
                          • Aug 2011
                          • 147
                          What is the condition of your ITB unit? I can see colours bleeding over the black prints. Have you done calibration with these prints to try to get the machine to correct the undertaking/grainy image
                          If it works, don't touch it.
                          • fshead
                            • 2376
                            you can set the machine to do single color and do a 2 inch sky shot and see the fill for cyan or yellow or magenta
                            How to enable single color mode - use SP5-618 change to 0
                            • anpetros
                              • May 2011
                              • 43
                              It was the fusing unit sleeve...Stil cannot beleive it .At 117k ,less than half of its life.That fusing unit...............Thank you very much for your help.
