Ricoh 5054 scan to folder to windows 10
  • aviso66
    • Dec 2012
    • 202
    [Misc] Ricoh 5054 scan to folder to windows 10
    Hi,
    Just would like to ask if ricoh mp5054, can it scan to windows 10 version 1809 using scan to folder?
  • Zeldaman
    • Mar 2011
    • 946
      Re: Ricoh 5054 scan to folder to windows 10
      Originally posted by aviso66
      Hi,
      yes but if you are an end user or a 'tech' without a SM.. don't try it .. if it's working.. it may not be after you are done.
      • aviso66
        • Dec 2012
        • 202
        Wat is SM
        I am not sure if the firmware are updated. This is what I found out from the machine.
        Module Name Version Part Number
        System/Copy 1.17 D2025550V
        Network Support 14.35 D2025564M
        Fax 08.00.00 D2025557K
        RemoteFax 02.00.00 D2025558D
        Web Support 1.06 D2025560D
        Web Uapl 1.04 D2025561D
        NetworkDocBox 1.06 D2025565J
        Font EXP 1 D1475581
        Java VM v12 std 12.30.01 D2025567L
        animation 29 D2025562C
        PCL 1.09 D2025566H
        Printer 1.08 D3A75701K
        RPCS 3.16.8 D3A75703C
        Scanner 1.07 D3A75704K
        PDF 1.03 D3A75733C
        PS3 Font 1.11 D6415763A
        PCL Font 1.14 M1095273
        Data Erase Onb 1 D2025556
        PowerSaving Sys F.23 D2025554D
        Engine 1.17:03 D2025501L
        OpePanel 1.05 D2025563F
        ADF 01.320:03 D7795300K
        • copier tech
          • 8111
          Hi,
          Try it most likely it will will work fine.
          The only issue is if you have SNB v1 disabled.
            Wat is SM
            Font EXP 1 D1475581
            PCL 1.09 D2025566H
            PDF 1.03 D3A75733C
            SM= Service Manual
            • aviso66
              • Dec 2012
              • 202
              Do I need to have smb 1 enabled for this machine? because i thought it support smb 1 and above. Yup, If smb 1 enabled from the computer it works.
              • aviso66
                • Dec 2012
                • 202
                scanning still failed to work for windows 10.
                testing Scanning SMB Version 2\3.
                reason to test smb 2\3 because some client would not like to have their computer configured to enable smb 1 features due to security issue. they prefer straight forward setup and scan.
                Scanning type: SMB Scan to folder.
                Windows 10 version 1809(17763.316).
                Error msg:
                Connection to pc has failed \ Connection with the destination has failed check settings. Entered path name might be incorrect, or firewall and security settings might be blocking network connectivity
                Research tested:
                1) No configuration changes from windows 10. just test setup folder for smb scanning-failed.
                2) change windows 10 local account setup for scanning to administrator level. - scanning failed.
                3) set scan permission at security to full control on scan folder- scanning scan failed.
                4) Tested changing networking sharing encryption at 128 bit and 56 bit- scan failed
                5) Ping from computer to ricoh and from ricoh to computer is successful.
                6) Using twain driver scan is successful.
                7) Tested scan to windows 7 is successful.
                8) Tested using IP instead of computer name on smb - failed.
                9) changes from just using username to username@domain at ricoh addressbook doesnot work too.
                10) scan to ftp is successful using windows 10 ftp features.
                11) clean install windows 10 same version OS without activation. scan still failed.
                12) allow an app through firewall, smb direct. scan still failed.
                13) Wireshark tested check showing 54 445 -> 65452 [RST, ACK] Seq=1 ack=168 win=0 Len=0 dunno wat is tat but its red colour showing something not communicating
                14) turn off defender firewall, off realtime protection, cloud delivered protection off. failed
                15) Telnet ricoh 5054, port 445, auth level 0, wsd browser on, write mode: sync, timeout 20. rebooted machine and tested still failed
                16)Telnet ricoh 5054, port 445, client auth level 1, wsd browser on, write mode: sync, timeout 20. rebooted machine and tested - failed
                17) Telnet ricoh 5054, port 445, client auth level 2, wsd browser on, write mode: sync, timeout 20. rebooted machine and tested -failed
                18) Telnet ricoh 5054, port 445, client auth level 3, wsd browser on, write mode: sync, timeout 20. rebooted machine and tested- failed
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  If it is not a Microsoft Office365 mailserver activate scan to email... solved.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    For a strange reason I had a 2051 in my mind...
                    It will work fine even with Office365 mailserver...
                    Sorry.
                    • sturmtrooper
                      Copier Combobulator
                      • May 2016
                      • 587
                      Wat is SM
                      Font EXP 1 D1475581
                      PCL 1.09 D2025566H
                      PDF 1.03 D3A75733C
                      Your firmware is below the levels required for SMB 3 support.
                      firmware levels.pdf
                      Those are the minimum levels for that machine to support SMB 3.
                      No I cannot provide you the firmware. You will likely have to pay someone to update the machine for you.
                      • aviso66
                        • Dec 2012
                        • 202
                        scan to email might not be relevant especially if they are scanning lots of file.
                        • aviso66
                          • Dec 2012
                          • 202
                          [ATTACH]41851[/ATTACH]
                          Ohh thanks alot , at least i know that the machine needs to upgrade firmware so i dont have to keep testing it until i upgrade the firmware.
