W3601, bad mojo.
  • mikadonovan
    • May 2008
    • 2931
    W3601, bad mojo.
    Hi, All. Here's the deal. I have a w3601 that I was running, and I had a misfeed which broke the separation corona wire. I replaced the wire, and then I was getting toner spotting. I went ahead and did a developer change, and changed the dev unit mylar seal, and the cleaning blade. Now I am getting this dark background crap. I inspected all connections, and they are ok. Does anyone have any thoughts on what might be causing this? This is one of those machines I have not been formally trained on, but I have a manual, and I am alone on this repair (just like all of them). Thanks, Mika
    NEVER ASSUME ANYTHING
  • fshead
    • 2376
    Re: W3601, bad mojo.
    i wish i could help you but i dont see any wide formats.
    The first copy was what you were getting b4 dev change?
    the 2nd what you have now?
    If so did you ck dev unit contacts,grounds,all corona end caps?
    it looks like the dev unit is losing bias..
    Again i am only thinking in mp6001 mode so if any of this if off i
    am only looking in terms of what i work on..
    • COPIERMAN
      • Jun 2009
      • 559
      I have never work on one. May take would be charge roller in drum unit no making connection.
      • zed255
        How'd ya manage that?
        • 1024
        Did you handle the charge corona assembly? Had similar once when I snagged a grid wire on a bracket, shorting it the chassis.
        • keithxxiii
          Just a tech
          • Nov 2014
          • 471
          There is a latch behind the charge corona assy that is quite difficult to reconnect. Also, when you change the transfer and sep wires, those 4 plastic guides should be installed accordingly. And again, recheck those connectors.
          Aye! Cut the crap
          • Brianneoe
            • May 2015
            • 322
            I'm assuming that the sample is from a counter page from another machine..If so..
            Its the recovery blade on the cleaning unit, worn to a point that its not bring the toner into the cleaning unit. Not bad to fix(figure 2 hours if its your first time) but its a expensive blade. Just be very careful of the drum..easy to scratch or ding and that cost is about 1G. You will need to pull out the drum. The trick is to loosen the drum drive pulley when removing and reinstalling the bracket with the 4 screws. Also there is a frame screw on the left side that you will want to un-screw so as not to interfere with the removal of the drum unit. Don't take the screw out completely but just enough so you can pull the drum unit out. Replace the drum cleaning blade while your there and also the main charge unit. That will add another hour to the repair but save you a recall. Again be very careful with the drum.
            Keep in mind that a contract for this machine is 10 cents per liner foot, so if the customer complains about the cost and he has 60K on the unit (about the time that the blade goes bad) he is already up 6G
            • fshead
              • 2376
              i dont think you are seeing his problem...
              he changed the drum blade,dev seal mylar,corona and developer.
              the pics i think are b4 and after dev,db replacements.........
              • Brianneoe
                • May 2015
                • 322
                i know i was a little long winded on my 2 cents but the recovery blade is the problem.
                • Brianneoe
                  • May 2015
                  • 322
                  Just to clarify..the recovery blade is the cause of the toner spots on your sample. The background is caused by the Drum being worn to the point of replacement. You can adjust the main charge up and the DV bias lower {more positive} to help with the tint but it won't be clean until the drum is replaced.
                  • fshead
                    • 2376
                    hmmmmm
                    Why would it be ok wth spots b4 developer and drum blade change?
                    I dont do these because the parts are so pricey and would hate to buy 1k worth of parts and
                    still have issues getting paid for some new issues.
                    I use to keep a small bottle of high voltage dope when working on machines with corona wire charge
                    systems and dope the plastic blocks for corona leaking etc etc
                      • 37556
                      Originally posted by fshead
                      hmmmmm
                      The spots are common on a drum that is due to be replaced. To get rid of them you need to replace drum, blade, charge, and cleaning brush. The over black print most likely has to do with a bad charge connection, laser is a WRITE TO NO CHARGE.
                      • mikadonovan
                        • May 2008
                        • 2931
                        No laser on this box, it's a LED print head.
                        • mikadonovan
                          • May 2008
                          • 2931
                          OK, I fixed it and thanks for the relies. The problem was I was working on the machine with all the covers off including the original feed table. The machine was in close proximity to a window and the sunlight was hitting the LED printheads somehow (a revelation that occurred to me over the weekend). Anyways, The image quality is back with the exception of a dark area on the edges of the print (about 3 mils). Adjusting the blank margins to 10 mm did not fix that issue. But, thank God I'm making progress. Sometimes I hate working on shit I haven't been trained on or don't know much about, and these machines are a pain. Everything is huge, and it takes forever to do even the simple stuff.
                          • mikadonovan
                            • May 2008
                            • 2931
                            Does anyone know what could be causing a dark edge? It's coming from the machine right side, both prints and copies, about 3mm wide. I appreciate the previous help I have received from members of this forum. This repair has been less than ideal, and I'm worried about my hair turning white. Oh, wait. It already is.
                            • JDYAL
                              • Sep 2008
                              • 187
                              Check the right side of drum for a wear marks. Sometimes you can flip the drum and it will take care of the problem. Also make sure that your cleaning unit seals are not leaking.
