Ricoh MP C307 - ITB waste buildup
  • Charles_112
    Field Service Engineer
    • Oct 2018
    • 4
    [CQ] Ricoh MP C307 - ITB waste buildup
    This is the second MP C307 that I have seen with waste toner piled up in front of the ITB cleaning section. The first one would only run a few ACC prints before piling up again and producing prints with incomplete fill-in of solids.
    I am new to this model. Is this "normal" and just needs to be vacuumed on a constant basis, or is there a something I am missing that will help them operate cleanly?
  • CSI
    • Oct 2008
    • 73
    Re: Ricoh MP C307 - ITB waste buildup
    I have the same "problem" on MP C306 and 307 every 40/45 K pages. A little vacuum and you're done
    • TonerMunkeh
      Professional Moron
      • 3865
      Depending on it's mileage the ITB unit will probably need replacing. There is a hell of a lot of paper fibre in that picture though, does the customer run particularly cheap paper?
      Hit it.
        • 37480
        I am in agreement with TonerMunkeh. That does not look like toner against the cleaning blade. It is either paper lint or air borne fiber from something in the environment such as short fiber asbestos.
          I agree with TM and Slim..
          • skinnyb
            • Jul 2008
            • 291
            Yes. That's cheap paper fiber. Hit it with a vacuum and go. I do it all the time.
            Sent from my VS987 using Tapatalk
            • gigio
              • May 2018
              • 3
              hello i m new in the forum
              i also have one mp c306 ans i clean the itb cleaning unit and after 20 copie is the same.
              the mfp arroun 70k in color
              do a realy need to change the itb ?
              thank
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                thank
                The transfer unit life is 120k if you tried cleaning out already I would replace
                Regards Mark
                • tsbservice
                  Field tech
                  • 8008
                  I don't know this model but if the belt is within life you can disassemble cleaning section and clean all the paper/toner cr.p inside. Then don't forget to stop using cheep paper/non original toner.
                  • gigio
                    • May 2018
                    • 3
                    Ok thank you very much i allready vacuum 2 time. The belt is good os just the cleaning system. Too bad we can t order just the system.
                      i would try a cleaning unit first... IF the belt isn't marked up
                      • gigio
                        • May 2018
                        • 3
                        I already trie. Vacuum 4 times
                          • 37480
                          Not cleaning the unit, replace or rebuild the ITB cleaning unit.
                            remove it from the belt frame... turn the auger.. vac it out... clean the blade with IPA and re-powder the blade..
                            are you even a TECH? because your profile doesn't indicate ANY TRAINING.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              They not expensive this happens all the time just order new {oem} and replace
                              Regards Mark
