mp c5503 fusing belt message
  • T911
    • Jun 2007
    • 628
    I can't get rid of this message. replaced the entire fuser reset counts, controller and nvrams also. driving me crazy. help appreciated (fusing belt unit must be replaced now)
    Re: mp c5503 fusing belt message
    sounds like you didn't clear the counter on the belt.. resetting counts doesn't clear indiv parts
    • guitar9199
      • Sep 2016
      • 1100
      Go into SP Mode >PM Counters
      Find the counters for the parts you replaced and clear them,
      Go into SP Mode> System SP
      3701-116 (fixing belt) and 3701-118 (Pressure Roller) can both be set to "1", then exit and reboot the machine.
      Hope this helps.
      • T911
        • Jun 2007
        • 628
        I reset the pm counts in sp and checked to make sure the yields were correct, did 3701-115-116-118, 7622-115-116-118 and checked 7803 was at 63 and performed pm reset too 7804. What keeps this information stored eprom or nvrams on this machine. By the way it will reset and come to ready after doing 3701-115-116-118 i can make a copy and then the message comes up after the copy comes out. WTF help appreciated.
        • copier tech
          • 8221
          Have you tried updating the firmware? what package is the machine currently on, from memory v27 is the latest.
          With the later fw you get an addition PM counter tab in service mode.
            • 37628
            Did you reset the individual parts, along with the PM counters. If you did not you will have to go back and reset the PM counters again and the parts counters. Then cycle power.
            • FrohnB
              • Jul 2017
              • 1919
              Did you let the fuser go to like 400k or above? I ran into one that wouldn't clear until I put the reset Fuse in with the new sleeve unit (Fuse comes with new fusing sleeve ass'y).
              Omertà
              • T911
                • Jun 2007
                • 628
                A reset fuse for the 03's I thought that was only for the 02's with the 544 error. Am I missing something here.
                • T911
                  • Jun 2007
                  • 628
                  Slimslob I really think I went through all of that. I will recheck and test again. This one is killing me.
                  • T911
                    • Jun 2007
                    • 628
                    Before I pull all the guns out i thought maybe someone came across this out there. Thanks for any ideas.
                    • The_man
                      • Jan 2016
                      • 40
                      Did you reset high heat sp after 5810, 002 .I think if it fails then you should check pluggable fuse on fuser, as said previously, comes with new sleeve.
                      • fshead
                        • 2378
                        i had something like that with a mpc3502 that would nt reset and ended up making a fuse reset jig wth a small door switch and the end connector to a thermister and some wire.
                        for some reason machine refused to blow that pico fuse and reset.
                        So after 15 attempts wth pressing the jig and timing the fuser reset it came back.
                        I started copying nvrams off all the machines i put out afterwards as i figure if it ever happens again i can
                        just revive the nvram to original working condition.
                        • Coptech
                          worker drone
                          • 460
                          Can you go to the end of the 3s, and on "manual set new unit, set fuser to 1?
                          • T911
                            • Jun 2007
                            • 628
                            Fyi, nvram guys. Thanks for the reply's
