C4502...Please wait after replacing the fuser sleeve. No SC 544-00
  • kyotech
    • Dec 2008
    • 20
    Got a tech that replaced a fuser sleeve in a C4502 due to a torn sleeve. He replaced the sleeve, installed the new fuse,ran SP5810-002 which resulted in a fail. Rebooted machine to a please wait on the display that won't clear. Updated all firmware, installed new fuser fuse and still please wait, resets SP5810-002 resulting in a fail result. Takes the fuse out, reboots to a SC561, replaces both thermistors same code. Puts new reset fuse in to a please wait again. Runs SP5810-02 to another fail message. Seems the machine is trying to blow the fuse but can't so it sits there at please wait. Now I normally won't replace the fuse unless there is an error code, replace the sleeve, reset the counts and all good. This is an odd one.
  • kleankopy
    • Feb 2016
    • 115
    Re: C4502...Please wait after replacing the fuser sleeve. No SC 544-00
    You probaly left the Thermister connector off when changing sleeve.
    • kleankopy
      • Feb 2016
      • 115
      or your tech put the fuse on the thermister plug.
      • andy227
        • Jan 2013
        • 219
        strong possibility of this, I agree, as the connectors are the same. However, he would have had to make the same mistake twice, when replacing the sleeve and then when replacing the thermistors.
        • ridgemill
          • Sep 2017
          • 190
          Entirely possible. You can check by removing the fuser, remove the fuse, and check continuity between the connector pins and the upper plug pins.
          Note: The pins marked here, may be different depending on region and/or model.
            • 37532
            The second time he merely connected everything the same as they were, not realizing that it was incorrect.
