Ricoh MPc4502 not surw what to call this
  • digicor
    • Jul 2008
    • 1159
    This what I get from just one PC in the office running win10, this same pc prints to a mpc7501 just fine, ive un installed,reinstalled,drivers are up to date, firmware is current, buffer is 256 font is set at 0,
    SKM_C3350190311154001.pdf
  • rhe
    • Feb 2013
    • 51
    Re: Ricoh MPc4502 not surw what to call this
    Have you updated fimware PCL,FONTS
    • digicor
      • Jul 2008
      • 1159
      i have updated the firmware, i will check and see if the fonts are in the update.
      • fshead
        • 2376
        looks like peyote mushrooms got mixxed in the toner..
          • 37532
          Since th e header and footer print correctly, I would look at the document itself. Maybe download it again.
          • LNorris
            • Sep 2008
            • 645
            instead of printing directly from website, save as pdf then print (like slimsbob indicated)
            • CopyBats
              • Aug 2011
              • 147
              After you've installed new drivers, make sure you've also closed and then reopened the actual browser itself you're printing from. I am assuming from the looks of it that this is a webpage that is being printed.
              Also take a look at print preview with the correct printer selected to make sure that the document shows correctly.
              If it works, don't touch it.
              • Mark Bbb
                • Jun 2012
                • 1662
                If the above "cure" is not working, and the printer is installed as "local" on that pc, erase the driver and reinstall.
                • digicor
                  • Jul 2008
                  • 1159
                  thanks Ill let you all know what fixes it...
                  • JDYAL
                    • Sep 2008
                    • 187
                    I have a bank that uses a certain type of software and it does not like Ricoh print drivers. Normally when this happens I have to contact there IT department to rectify the issue. Same problem with a bowling alley that uses same type of software. I have had an older print driver solve the problem. Not sure if this applies to your situation just adding my 2 cents.
                    • digicor
                      • Jul 2008
                      • 1159
                      older print drive? Hmmm okay , its worth a try
                      • MitchD
                        • Oct 2012
                        • 164
                        I would be more concerned that the customer still running a c7501
                        "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                        • digicor
                          • Jul 2008
                          • 1159
                          yeah, hahahaha i know, but they seem to be attached to it like kids blanket... Ive made several attempts to rid them of it,, No luck, even gone as far as giving them a deal no one else could say no to , and yes,, they said no to it... LOL
                          as long as i keep it running,but that day is coming.!!!
