Looking for updates on those here that are rebuilding the mpc3503/04 drum units
  • fshead
    • 2356
    hi
    I am looking to stock up some drums.drum blades,lub bars for some mpc3503/mpc4503 series i have in the field.anD is there any difference in drum from mpc2503 to mpc4503?
    I am curious how they are holding up and is there anything else you change PCR?cleaning PCR.
    ANy tips you find?
    thanks
  • NJBecker
    Re: Looking for updates on those here that are rebuilding the mpc3503/04 drum units
    If you send me your email address, I'll send you Q2's rebuild instructions.
    • anothertech
      • 1756
      Originally posted by fshead
      hi
      ANy tips you find?
      thanks
      I didn't know those parts were avalible, are they normal parts through Ricoh?
      • fshead
        • 2356
        as for rico i dont swim in that ocean but i dont think so..
        What i know from previous experience rebuilding fax and printer cartridges is there were grade A
        Japanese drum and grade A German drums..YOU HIT THEM WTH A hammer and they would not
        show it..now there is a lot of Korean and Chinese and some of them might be suppliers to rico themselves...
        • mikadonovan
          • May 2008
          • 2931
          The Q2 '03 pcu rebuild kits have been working ok for me. Be sure and use the Q2 lube bar as it is better than oem. And don't lose the tiny springs from the charge roller assy.
          NEVER ASSUME ANYTHING
          • CopyBats
            • Aug 2011
            • 133
            Hey,
            Do you happen to have the instructions for the Q2 rebuild?
            How would you rate their performance now?
            Thanks for your time
            If it works, don't touch it.
            • mikadonovan
              • May 2008
              • 2931
              Originally posted by CopyBats
              Hey,
              I have experienced early failure on these. I could only do B&W scan to keep the file size under the limit, and it doesn't look too good.
              • FrohnB
                • Jul 2017
                • 1919
                Just fit the Cxx04 drums (D2392243) in the '03 machine (as long as it's C3xxx on up). No mods (except for the normal lube bar spring adjustment).
                Not sure how much your rebuild kits cost, but i know the cost of the '04 drums is Substantially cheaper than the '03's.
                Omertà
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Rebuild kits are a waste of time just fit the correct parts or 04 pcu's in 03 as they a little cheaper to buy
                  Regards Mark
