Ricoh MP 6001
  • Reed
    • Feb 2011
    • 255
    Ricoh MP 6001
    Customer was complaining that the tray 1 elevator doesn't always lift the paper when it is full of paper. They have to remove most of the paper for it to lift and then it starts working again. I tested out the machine but had no problems with the elevator lifting the paper. Do the lift motors go out in this machine.. I know it is old but the customer really likes this machine. Thanks in advance
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Ricoh MP 6001
    First thing I would do is make sure the elevator tray and the two metal guides it slides up along are not bend. I've seen many of those guides get bowed outwards and cause the lifted part of the tray to bind up. If that's fine I'd check the cables that lift the tray are in good shape and properly routed. If that checks out then I'd repeatedly make it try to lift a 3/4 full tray several times in a row to see if you hear anything from the motors or can get it to fail.
    • Codex
      • May 2008
      • 694
      Re: Ricoh MP 6001
      Check the sensors that are actuated by the front fence..... The machine check these sensors before lift the plate.....
      Inviato dal mio SM-G935F utilizzando Tapatalk
      Memento Audere Semper
      • apump
        • Mar 2009
        • 160
        Re: Ricoh MP 6001
        the front end fence is probably broken.
        • Mark Bbb
          • Jun 2012
          • 1662
          Re: Ricoh MP 6001
          Tray 1 is not a LCT.
          Everything wore out, also a lift motor.
          Even better is to sell a new machine...
          • davel
            • Oct 2011
            • 1089
            Re: Ricoh MP 6001
            Tray 1 is usually a tandem tray which takes more paper than a normal tray so it does have large capacity.
            • fshead
              • 2356
              Re: Ricoh MP 6001
              Check fences,sometimes crack at the pin,check the 3 photosensers as they pop off and pull tray and turn by hand watching the cables,tray etc for anything blocking or binding...
              also ck the wiring ...
              These machines are like cockroaches,they will outlive mankind.........
              • NeoMatrix
                Senior Tech.
                • 3514
                Re: Ricoh MP 6001
                All except for the fuser drive gear.....
                • davel
                  • Oct 2011
                  • 1089
                  Re: Ricoh MP 6001
                  Fit the new one and change the pressure roller.
                  • fshead
                    • 2356
                    Re: Ricoh MP 6001
                    true but i am glad for those calls as it quick money..
                    If I had everyone on contract i would want the 1075 fuser..big fat upper roller
                    and much better design than that skinny 6001 ufr..
                    • anothertech
                      • 1757
                      Re: Ricoh MP 6001
                      The fusers with the big pressure rollers take a long time to warm up coming out of sleep, many customer complaints.
                      The gears don't break on the skinny fusers as long as the fusers are rebuilt when they are due at 450K, and the gear is replaced about every third fuser rebuild.
                      • fshead
                        • 2356
                        Re: Ricoh MP 6001
                        i dont find that...and i think that skinny roller is not a good design..
                        The surface should be harder....
                        I know the old heavy 1075 roller took longer to warm up but they ran n ran..
                          • 37037
                          Re: Ricoh MP 6001
                          Actually it is the size of the fusing roller and its thickness that affect warmup time. The newer 50-80 ppm model with thinner fusing rollers and therefore less metal mass to warm up, take much less time to warmup.
                          • stani
                            • Jan 2013
                            • 49
                            Re: Ricoh MP 6001
                            If you (topic-starter) mean the 1. Tray,
                            I had the same issue - actually it was nothing really wrong with the machine. All I had to do is to take all the paper from both trays, insert the empty trays in the machine, let it recognize it, an than to fiil the paper, afterwards everything worked without any issues for many months.
                            Btw I show all my customers the best way to fill paper in this tray:
                            1. fill only the left tray (it is much more convinient to fill),
                            2. insert both trays, and let the machine transport the paper to the right,
                            3. fill the left tray once more.
                            Those who use this method, never break the fence.
                            • fshead
                              • 2356
                              Re: Ricoh MP 6001
                              My customers end up bending the right side rear metal frame because they heavy hand the paper load.
                              I too tried telling them load the beefy left side tray and they respond i cant wait for it to load..
                              I give up and just go thru my day...
