MPC4503 power save
  • kwehner
    • Mar 2009
    • 47
    MPC4503 power save
    I am having 2 issues with the same MPC4503, after it goes into sleep mode it will not come out unless you power cycle the machine. It does not recognize putting a document in the feeder, lifting the feeder or pressing the Energy Saver button. It will not print in sleep mode either. The only way to use the machine is to turn it off and back on.
    The other issue is I cannot get into SP mode. I looked for Service Lock Mode in user tools and cannot find it. I can get in using factory mode. I attached a copy of the firmware versions in the machine.
    Any help is greatly appreciated.
  • COPIERMAN
    • Jun 2009
    • 559
    Re: MPC4503 power save
    service mode are you using the old code for service mode or the new code
    • COPIERMAN
      • Jun 2009
      • 559
      i havempc4503.pdf attached firmware info. go to user tools then system settings then administrator tools then firmware version and compare if they are latest. the service mode lock only shows up if the admin. autho. management features are turn on in admin tools section.
      • davel
        • Oct 2011
        • 1107
        Try replacing PSU for wakeup issue
        • copier tech
          • 8172
          Some of your firmware is out of date update ALL the files not just package. The power fw should be on v 20.
          If you can get in SP mode set SP5-191 to 0 this stops the controller from going to sleep (the machine will sleep as normal)
          • davel
            • Oct 2011
            • 1107
            I just looked at MP 301, no SP 1-191
            • copier tech
              • 8172
              SP 5-191 the little 301 may not have this SP.
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                Copier Tech is absolutly right. 1. update package, 2. update module! The newest version of power saving sys is D1495554E (vers. 20). After update this problem is gone.
                Greetings...
                • kwehner
                  • Mar 2009
                  • 47
                  Thank you for your help the firmware fixed the power save problem!
                  Still cannot access regular SP mode, can only get in with factory mode.
                  • guitar9199
                    • Sep 2016
                    • 1100
                    In Factory SP Mode, you can check SP-5081 to see what the SP Mode password is, and change it if you need to. I would STRONGLY recommend you make it the default PW for SP mode.
                    • copier tech
                      • 8172
                      Set an SP mode password?
                      • paulg
                        • Jun 2007
                        • 278
                        You can change the SP mode entry code i.e normally its the number sequence we all know and love, but you can choose to change it. But of course, unless every Tech knows what the new code is it can be annoying if you don't or have to ring around to find out.
                        • copier tech
                          • 8172
                          Thanks, I wasnt aware of this, might change a few to wind up my engineers!
                          • paulg
                            • Jun 2007
                            • 278
                            Ouch, LOL make sure you don't try it on those Techs who dive into quick or you might have wiped Ricohs and annoyed customers
                            I know it's frowned upon to change by most Techs I know, but in some schools and so on it can be a must!!
