can i use a mpc5502 fuser sleeve on a mpc3502?
  • HitMan
    • Aug 2015
    • 170
    #16
    Re: can i use a mpc5502 fuser sleeve on a mpc3502?
    It's what ricoh did they made the belt one part no.
    I only fit the same part to all of the different mpc 02 models
    Sent from my SM-G930F using Tapatalk
    • fshead
      • 2376
      #17
      WHen you change just the belt are you changing the inner cotton lube too?
      I have to assume that is there to provide high temp lubrication
      • HitMan
        • Aug 2015
        • 170
        #18
        When you buy the genuine part from ricoh it comes as a whole assembly
        • fshead
          • 2376
          #19
          i misunderstood..
          I was under the thought that the 45cpm to 60cpm units have more heat ability needed for hi speed.
          IT Would be nice if parts could cross over..
          • HitMan
            • Aug 2015
            • 170
            #20
            The part no I use is D144 4273 and fits mpc 3002/3502/4502/5502
            • HitMan
              • Aug 2015
              • 170
              #21
              I'm in the EU
              • fshead
                • 2376
                #22
                I'm in the EU
                ahh.that could explain things.I am 110volt...
                • HitMan
                  • Aug 2015
                  • 170
                  #23
                  But there must be one for your area that fits accross too. I would imagine
                    • 37503
                    #24
                    Look at the bulletin. It has the part number for the North American, 110 volt, version.
                    • FrohnB
                      • Jul 2017
                      • 1919
                      #25
                      Ricoh's most updated Parts catalog for the C3002/C3502 (updated 3/7/19) shows D1424272 (NA) and D1424273 (EU).
                      Ricoh's most updated Parts catalog for the C4502/C5502 (updated 11/8/18) show D1444272 (NA) and D1444273 (EU).
                      Ricoh Hotline says there is no such sleeve that crosses all models.
                      We have tried using the higher speed sleeves in the slower speed and vice versa, and always got a code. Best to just stick with what's supposed to be in there.
                      Omertà
