Mpc3500 no black toner
  • mrfuser
    • 1617
    Replaced black toner pump and tube, black drum and dv unit. Ran forced toner. I have the back off and can see it is adding through the tube yet still shows no toner for black. Also replaced black toner cartridge. If I do an sp3045 it will print fine then reboot after changing back and it will show a few bars of toner , make a few copies and it goes back to no toner!
    also swapped end toner detection sensor.
    What’s up with this?!?
    • 37393
    Re: Mpc3500 no black toner
    If it works with SP 3045 turned off, leave it that way. The toner end detection sensor will still alert when the tone runs out. It also eliminates users wasting toner by replacing bottles just because the toner low message comes on.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      Probably RFID board. Might as well just leave it turned off instead of wasting the money.
      • mrfuser
        • 1617
        Ok so when it runs out of each color it just stops and makes them add it?
        • fshead
          • 2367
          no
          i think it will code out sc360 or so..if the toner level drops out...
          HOW are you seeing it add toner?
            • 37393
            Originally posted by fshead
            no
            When the toner end sensor on the back the toner bottle nozzle detects no toner coming out of the bottle, it will immediately go into a toner end condition.
            I have run a number of Ricohs this way when the RFID chip is bad on a nearly full bottle. Once the bottle is empty and has been replaced, 3405 can be turned on.
            • mrfuser
              • 1617
