Image moves around on page, side 2 doesn't register
  • rightbrained
    • Oct 2014
    • 40
    [CQ] Image moves around on page, side 2 doesn't register
    I've had this same issue with other copiers I've owned. Now it is happening on my Lanier LD525C.
    When I run 80# cover (for business cards) through the bypass feeder, the image moves around on the page... sometimes as much as an eighth of an inch. Then, when I run side 2, the same happens, So some sheets may be a full quarter of an inch out of register.
    I think the problem starts at the bypass try when the sheet is being pulled in. Are there any tricks or alternative methods to fix this issue and keep sheets in register?
    • 37628
    Re: Image moves around on page, side 2 doesn't register
    Clean the bypass pickup roller. Hand cleaning wipes such as Scrubs as they have pumice grit that helps remove the dust that gets embedded in roller surface.
      Is this printing to it or copy?
      GLOSSY media? Is it set that way in print driver and tray config?
      Are you sure guides are tight to media in the tray?
      What's the page count on the machine?
      Like Slim said.. rollers clean? worn?
      Phil 'The Dentist'
      • rightbrained
        • Oct 2014
        • 40
        Phil 'The Dentist'
        PRINT to non-glossy stock. Old machine - high page count. Tight guides. Probably worn pickup roller on bypass tray. Trying Slims idea but appreciate other thoughts.
        • tsbservice
          Field tech
          • 8064
          The simple trick is to help sheet feeding by push it with your hand.
          But that's not the remedy. Your bypass rollers may be dirty(as others suggested), they may need to be replaced, even on some models there is adjustments of bypass to help with feeding thick paper.
