MP2000 Tray 2 Feed issues
  • xcopier
    • Aug 2015
    • 36
    Hi,
    Lately the machine has been having issues with paper coming from Tray no. 2.
    Sometimes the paper would just stop before reaching the registration rollers, sometimes it stops when the paper is about to come out.
    And the copies are often off by a few inches. I have attached a picture to visualize the problem. The one on the left is the original and the one on the right is the copied print. When i copy documents with letterheads or a short top margin, it will either be on the very top edge or not printed at all.
    I have tried cleaning the clutches and rollers but the problem resurfaces. I also tried swapping trays but to no avail.
    The upper tray have no problems whatsoever. Prints come out just fine.
    Thanks for the inputs.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP2000 Tray 2 Feed issues
    Have you actually fitted a new clutch?
    Hit it.
    • FrohnB
      • Jul 2017
      • 1919
      +1 on this.
      Also, check the lower right hand door (beside tray 2), and make sure that the locator post is still there (goes into a hole on frame near front side of machine). Have had these break off and cause issues.
      All sensors cleaned? Working?
      Omertà
        • 37422
        Does the red arrow indicate the direction of paper travel? If so, your problem might be the tray side fences. I have had them actually move when the drawer is closed. The momentum of the paper will push the rear fence back. THe harder you close the drawer,, the more it moves.
        • mikadonovan
          • May 2008
          • 2931
          Here is a sp to adjust that may make a difference. Jam codes are always helpful to identify the problem area.
          NEVER ASSUME ANYTHING
          • xcopier
            • Aug 2015
            • 36
            That is just to indicate the difference between the original and the copy that comes out. But even in A4 or Letter size that goes in sideways, the prints will be off by a few cm or inches on the right side.
            I have checked the side fence and they haven't moved.
            • skinnyb
              • Jul 2008
              • 291
              I agree with this. Either feed or vertical path clutch is probably shot. If the follower rollers in the door are not touching properly it can slip there too.
              Sent from my VS987 using Tapatalk
              • Lagonda
                • Aug 2008
                • 1649
                Paper being lifted firmly against the feed roller?
