I have this code, with the following symptoms : 1. Machine reboots, after that it shows the SC-406 code 2. Partial printed drawings all over the printed paper, unreadable. So far i have replaced T/DT corotron assembly, T/DT Power Supply and Drum-for other reason this. Machine works for some days without a problem and then it codes again. On/Off and continues..
Thanks a lot for any input..
