MP W2401 PS CODE SC-406
  • JDYAL
    • Sep 2008
    • 187
    #16
    Re: MP W2401 PS CODE SC-406
    Also check the developer gear cover, have had this thing not allow the machine to make proper gear contact and cause problems. I'll attach image.201904080907.pdf
    • Polo-022
      • Sep 2007
      • 484
      #17
      Developer gears have been checked for blockage, slipping, or partial breakage.
      I have never had to replace a motor too.
      • JDYAL
        • Sep 2008
        • 187
        #18
        Not sure if you solved your problem but I was thinking about a machine I had that with a similar problem. It ended up being a worn drive gear. The inside of these gears are brass and had worn completely. This machine had about 500,000 linear feet on it. I will attach an image. Hope this helps.
        • Polo-022
          • Sep 2007
          • 484
          #19
          I use to check all these gears very often for corrosion and lubricate them with G501 Ricoh Grease, internally.
          Thanks a lot JDYAL!
          It seems that problem has gone, today i had a communication with my customer, he said everything works fine...
          What's next??
