Streaks after adding New Y toner ctg Mpc 4502
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Just got a text message from customer.........copies were perfect. They changed the Yellow toner and now it has very defined streaks. Will be going out today to diagnose. Very interesting symptom. Ideas appreciated.........,,,See pic
  • HitMan
    • Aug 2015
    • 170
    Re: Streaks after adding New Y toner ctg Mpc 4502
    Definitely looks drum related, possibly a charge roller issue make sure it's making proper contact with the drum surface on both sides
    Sent from my SM-G930F using Tapatalk
    • blazebusiness
      • 1250
      Certainly looks like pcu issue........... those marks sure are unusual though. They say they just added toner but maybe there's something that the customer isn't telling me. We'll know more once we arrive and check it out.
      • mikadonovan
        • May 2008
        • 2931
        Probably so. I can't see how just adding a toner cart would cause that. Those streaks are pretty wide.
        NEVER ASSUME ANYTHING
        • blazebusiness
          • 1250
          My thoughts exactly............but a customer would never never never ever mislead their technician, right?
          • Coptech
            worker drone
            • 460
            They kinda have a ring of looking like lost gummed label fragments don't they?
            • blazebusiness
              • 1250
              Yes, a lot like the adhesive strips/margins that stay on the page when you remove the labels from the sheet. But why only the Yellow PCU? How did the other drums avoid the label material if that's what happened. And the only toner that was replaced was the Yellow. But enough speculation on my part. I'll get back with you all after we get a tech's eyes on the issue.
              • fshead
                • 2376
                maybe ask them to save the old cartridge and put it to the side.
                • MIGUELMARCHENA
                  • Feb 2018
                  • 192
                  It has happened to me when changing toner
                  do cleaning in the imaging unit, it has worked for me
                  regards
                    • 23006
                    Sometimes the "Add Toner" indication is a symptom, not a cause. For example, what if the yellow was massively over-toning and is sucking the cartridge dry? The developing unit may be so full of toner that it poofing out of every seam in the developing unit. Have a peek in the waste bottle: is it very full of yellow toner?
                    On Toshibas it's common to have a rear primary charge insulator break. When there's no yellow charge the machine entirely coats the primary transfer belt with yellow toner, depleting the developer in about 10 seconds. The customer calls for "Add Toner Yellow". The toner add system just can't add toner as fast as it's pouring out of the developing unit. =^..^=
                    • blazebusiness
                      • 1250
                      Nope, much less complicated than that. The copier had labels stuck to and inside the Y PCU , the ITB cleaning assy , and adhesive on the metal reg roller. So it was nothing to do with the Y toner change after all. Cleaned it up as best we could. They will have to foot the bill for a Y drum and ITB cleaning unit if CQ issues persist.
                      Thanks guys, for all the replies. I'll be sure and return the favor.
                      P.S. funny how all that label material skipped the other 3 drums and only the Y drum took a hit though.
