Ricoh MP C2050 tray 2 doesn't feed
  • Ricky965
    • Mar 2008
    • 36
    It's not the tray as I've tried another. Paper starts out but it seems the next roller is not turning as it doesn't begin it's upward path
    Re: Ricoh MP C2050 tray 2 doesn't feed
    other than the tray what else have you tried?
    1) page counts on feed parts
    2) total page counts
    3) condition of feed rollers
    you give NO information to help with your issue.
    • mikadonovan
      • May 2008
      • 2931
      Little light on info. Feed pulleys? vertical trans guide out of position? dirty feed sensors? faulty clutch? Paper size wrong? What have you done/checked out so far?
      NEVER ASSUME ANYTHING
      • copier tech
        • 8192
          • 37556
          Bad spring clutch for the relay roller.
          • Codex
            • May 2008
            • 704
            Pull out the first paper casette and look at the two small rollers that are under the small door at the right of the 2nd paper casette.... Sometimes the don't turn evenly and the paper slips
            Inviato dal mio SM-G935F utilizzando Tapatalk
            Memento Audere Semper
            • kwehner
              • Mar 2009
              • 47
              Bad spring clutch for the relay roller. X2
              Part #D0391172
              • FrohnB
                • Jul 2017
                • 1919
                Check the black guide for tray 2. On rear side there is a tab that pushes on a little push switch, and I've had these broken off before. Have also had the paper full sensor above the tray broken off and preventing paper from leaving tray.
                Not much else but the basics: Clean Feed roller/ check sep. pad/ make sure end fence isn't too tight or too far away from paper/ all sensors check out - not dirty.
                Otherwise, +3 on the clutch.
                Omertà
