SC495 on Ricoh pro 906 ex
  • jacanape
    • Feb 2019
    • 22
    [Error Code] SC495 on Ricoh pro 906 ex
    Hi there...
    I'm having error code SC495. The machine keeps on running but the prints are fading. What ment to be black becomes grey...
    So probably the tonersupply is clogged. Is there anyone out there who can show me the steps that I should follow to detect and resolve this problem?
    Thanks, Peter
  • khaled_mohamed
    • Mar 2019
    • 6
    Re: SC495 on Ricoh pro 906 ex
    SC495:
    Cause:
    Toner Bottle Unit Error During toner transport from the toner supply cylinder to
    the toner hopper, the toner hopper sensor cannot detect
    toner even after the toner supply pump switches on for 2s and switches off 10 times
    during copying.
    Remedy:
    connector loose, broken, defective
    cylinder defective
    defective
    defective
    • davel
      • Oct 2011
      • 1099
      Call your friendly Ricoh trained technician and pay them to fix it.
      • anothertech
        • 1766
        Yeah, toner supply tubes are probably clogged, was the machine moved with the toner still in the tubes?
        • jacanape
          • Feb 2019
          • 22
          The problem is detected and fixed with the help of khaled_mohamed :-)
          The upper toner container made a weird ratteling sound when moving, so I took it out . Then the machine switched over to the lower bottle.
          Now the tonerflow is OK again so problem solved. So I think I have to fix/replace the system that turns the tonercontainer. Any ideas how to fix that?
          Thanks everyone!
          • davel
            • Oct 2011
            • 1099
            Yes same as my previous post.
