it's possible scan to folder with spc232 in W10 ?
  • aguatepe
    • Jul 2015
    • 28
    Good morning
    I am trying to configure this printer model to scan to folder, since I understand that it does not work with win10 protocols.
    I have tried in windows features activate SMB 1.0 but it does not work either.
    Any solution or do I have to resort to scan to email?
    • 30279
    Re: it's possible scan to folder with spc232 in W10 ?
    Does it scan to ftp use filezilla server
    • aguatepe
      • Jul 2015
      • 28
      It's an option but I almost prefer to scan to email. Thanks
        Originally posted by aguatepe
        Good morning I am trying to configure this printer model to scan to folder, since I understand that it does not work with win10 protocols.
        have you checked into firmware for SMB2?
        there are known issues with Win7 &10
        there are plenty of threads on this issue with other brands also
        • copier tech
          • 8167
          Exactly, update the firmware this will enable you to scan SMB.
            • 37521
            SMB2/3 firmware is not available for this model and as I believe that this model is not made by Ricoh there most likely will ever be one. SD firmware is not available. Remote firmware available are Engine v1.06 and Main v 1.30 from rfgesource and v1.59 from TSRC.
            Microsoft no longer supports SMB1.0 on Windows 7, 8, 8.1 or 10. There were authentication changes with SMB1.2 on Windows 7 that SMB1.0 does not support. If you really want to SMB scan to folders on a Windows machine, find an old Windows 98 machine. Or setup a Linux virtual machine on Windows 10 and use Samba.
            • sandmanmac
              • 3981
              I only have one of these POS machines in the field. one gave 1 to a relative for nothing .
              I setup scan to folder on Win10 with SMB V1 enabled without a problem (surprised the hell out of me !).
              That's all I have to add
              • aguatepe
                • Jul 2015
                • 28
                Did you manage to run this model in windows 10? I tried to enable SMB1 in windows features and it did not work for me. If you say it worked for you, I probably made a bad configuration on the copier
                  • 30279
                  NEVER NEVER NEVER enable SMB1
