Ricoh MP C6502 SC220-01
  • Bassman1
    • Apr 2019
    • 2
    [Error Code] Ricoh MP C6502 SC220-01
    Original problem J001 try to clear turn into SC514
    problem being pinch wire on shift roller left motor .
    Replaced motor and DUB (blown fuse) and the paper deed PCB at the same time and now I have an SC220-01, so o change the laser bk/c and still the same code .
    • 37376
    Re: Ricoh MP C6502 SC220-01
    Did you check/replace the Black sync detector?
    • Bassman1
      • Apr 2019
      • 2
      Yes itbwas part of the bk/c laser assembly
